1 страниц (10 вхождений)
Fractal Tree - a programme for displaying a fractal tree - Сообщения
#1 Опубликовано: 15.03.2020 14:48:37
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7 КиБ) скачан 76 раз(а).
fractal tree.pdf (209 КиБ) скачан 81 раз(а).
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Thank you
Gerard Bush
Davide Carpi 16.03.2020 12:19:00
#2 Опубликовано: 15.03.2020 18:30:25
WroteI would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Like this ... in ½ points.
fractal tree.sm (11 КиБ) скачан 71 раз(а).
#3 Опубликовано: 16.03.2020 07:13:02
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17 КиБ) скачан 60 раз(а).
#4 Опубликовано: 16.03.2020 08:16:56
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18 КиБ) скачан 60 раз(а).
Cheers,
Gerard
#5 Опубликовано: 16.03.2020 09:04:22
Davide Carpi 16.03.2020 12:19:00, Alvaro Diaz Falconi 17.03.2020 16:15:00, Вячеслав Мезенцев 16.03.2020 13:59:00, frapuano 16.03.2020 09:35:00, Gerard Bush 16.03.2020 10:55:00
#6 Опубликовано: 16.03.2020 17:55:35
WroteThat is just what I was looking for.
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11 КиБ) скачан 61 раз(а).
Pattern Frieze Heppi.sm (11 КиБ) скачан 63 раз(а).
Pattern Hilbert.sm (8 КиБ) скачан 52 раз(а).
Pattern Patch Work.sm (10 КиБ) скачан 66 раз(а).
Pattern Fractal Sierpinski.sm (10 КиБ) скачан 57 раз(а).
Pattern Snail.sm (26 КиБ) скачан 60 раз(а).
Pattern Fern.sm (19 КиБ) скачан 61 раз(а).
Pattern Sierpinski Kover.sm (16 КиБ) скачан 61 раз(а).
Pattern Etoile Magic [Short].sm (46 КиБ) скачан 59 раз(а).
Pattern Sierpinski Triangles.sm (35 КиБ) скачан 59 раз(а).
Pattern Prototile.sm (116 КиБ) скачан 64 раз(а).
#7 Опубликовано: 16.03.2020 17:59:14
Pattern PythagorasTree.sm (6 КиБ) скачан 72 раз(а).
#8 Опубликовано: 17.03.2020 15:24:27
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11 КиБ) скачан 72 раз(а).
Gerard Bush 18.03.2020 09:56:00
#9 Опубликовано: 18.03.2020 09:58:54
Thank you very much, Jean and Ber7 for your additions!
#10 Опубликовано: 18.03.2020 12:06:31
Davide Carpi 18.03.2020 15:07:00, Gerard Bush 18.03.2020 16:59:00, NDTM Amarasekera 19.03.2020 06:03:00
Новые сообщения
Нет новых сообщений
