1 страниц (4 вхождений)
Quaternion rotation - Comments & Collaboration will help - Сообщения
#1 Опубликовано: 22.08.2015 01:13:05
Lovely Breather, Wikipedia has deleted the original image from 10 years ago.
Mathcad 11 is unbeatable for Breather up to meshing 199.
Smath does very good job.
Just too bad I can't make a colored plot like the GNU plot Kuen surface.
Wht's the trick to make Maxima plot work ?
jmgiraud@bell.net
Rotate Breather [Quaternion].sm (50 КиБ) скачан 130 раз(а).
jmgiraud@bell.net
#2 Опубликовано: 22.08.2015 17:32:22
Sometimes the Maxima function Solve can replace the Mathcad solution block, see attachment.
What is the problem with Maxima plotting? Please give an example of what you try and how it fails.
#3 Опубликовано: 27.08.2015 12:08:05
"Sometimes the Maxima function Solve can replace the Mathcad solution block, see attachment.
What is the problem with Maxima plotting? Please give an example of what you try and how it fails."
_________________________________
Thanks Martin,
I have remade Quaternion that will work independently of Maxima.
I'm puzzled reading the error message "forcibly" ?
Does it mean Andrey is no authorized to let Smath users to access Maxima ?
No way I could make Breather plot something like the 'Kuen' surface example.
You will understand all by reading the attached Smath WS.
Cheers, be good ... Jean
Rotate Breather [Quaternion].sm (311 КиБ) скачан 111 раз(а).
Thanks Martin,
#4 Опубликовано: 30.08.2015 08:02:18
As to the error message: Do you use the portable version with maxima? (with everything pre-installed). Closed connection may happen if maxima is crashed.
Maxima can access gnuplot 3d functions, for examples have a look at the handbook section 5.1.
I can't reproduce the Mathcad plots, there might be translation errors between smath and maxima, but it works for the example from the gnuplot homepage given in the handbook (Kuen's surface, the function does not include hyperbolic functions)
At least, the attached sheet gives a starting point.
rot.sm (426 КиБ) скачан 101 раз(а).
Новые сообщения
Нет новых сообщений
