Numeric up-down Region
Numeric up-down Region - Adds a numeric up-down control - Сообщения
#1 Опубликовано: 06.02.2014 14:29:04
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Numeric Up-Down Control.
  • requirements: SS 0.96.5146 or later;
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: Numeric up-down Region.sm (28 КиБ) скачан 102 раз(а).;
  • languages: English;
  • main features:
    - Allowed inputs: region up/down buttons, + and - keys, mouse wheel; hold the input to have more increments.
    - Settings: double-click over the region.
    - Output: place a variable in the region placeholder.
    - Size driven by the value (manual resize not allowed).
    - Adds the same control in SMath Viewer.
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Показать спойлер
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabelNumericUpDown | PathPicker | RadioButtonList | Slider
Вячеслав Мезенцев 07.02.2014 03:57:00, sergio 07.02.2014 05:06:00, IVR 07.02.2014 16:00:00, Radovan Omorjan 07.02.2014 02:19:00, ioan92 09.03.2014 13:22:00
#2 Опубликовано: 17.03.2014 19:02:55
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
- hidden the outer frame (still remains as transparent to avoid interferences with resize markers).
#3 Опубликовано: 18.03.2014 19:18:44
Davide, it seems that description strings of the region are ignored in the viewer. Can that be changed or do I need to use sort of "nice" variable names?
Notenschlüssel.sm (11 КиБ) скачан 109 раз(а).
#4 Опубликовано: 18.03.2014 19:48:19
I'll do it Martin... previously I've noticed a bug, now seems that the description text it works
#5 Опубликовано: 22.03.2014 13:44:41
UPDATED
- SMath Viewer: uses the region description (if exist and is shown).
ioan92 22.03.2014 13:59:00
#6 Опубликовано: 22.07.2014 04:56:30
Hello Davide,
It seems that the numeric up-down region remains active even when control is not checked
[albumimg]356[/albumimg]
After using the mouse wheel
[albumimg]357[/albumimg]
win7
smath 0.97 build 5301
Davide Carpi 22.07.2014 06:37:00
#7 Опубликовано: 22.07.2014 05:48:40
Grazie Sergio
Fixed, PLUGIN UPDATED
sergio 22.07.2014 09:48:00
#8 Опубликовано: 08.10.2015 10:36:19
I think it is possible...
Something like in the attachment? The entry point for the variable would be the form (like in table region) or in the context menu (like in the modeller region); this should grant customizable settings for every region, when you have multiple regions.
ioan92 08.10.2015 10:58:00
#9 Опубликовано: 28.10.2015 11:55:55
PLUGIN UPDATED SMath Studio 0.97.5737
- Introduced settings from canvas (see attachment);
- History Undo/Redo now is supported;
canvas settings.sm (17 КиБ) скачан 174 раз(а).
Andrey Ivashov 28.10.2015 16:35:00, ioan92 28.10.2015 12:15:00, NDTM Amarasekera 28.10.2015 12:40:00, sergio 28.10.2015 13:49:00
#10 Опубликовано: 22.09.2021 10:44:14
Not a bug but a cosmetic issue.
In Linux, plugin shows two square on each side of the value.
They are not written to variable, fortunately.
Davide Carpi 22.09.2021 14:43:00
#11 Опубликовано: 22.09.2021 14:47:54
Thank you, it appears because the thin space character is not available in that font (the irony... was added for cosmetic reasons too... )
I'll get rid of it for a more robust alternative.
#12 Опубликовано: 04.10.2021 07:48:47
PLUGIN UPDATED SMath Studio 0.99.7822 and later
  • buttons are now made by vector drawing;
  • removed thin spaces because issues in mono fonts;
sergio 04.10.2021 10:00:00
#13 Опубликовано: 25.10.2021 14:12:35
Renzo Choque
Renzo Choque
6 сообщений из 18 понравились пользователям.
Hi, it seems that the "canvas setting" field does not recognize the "whatever" variable. I'm using smath in windows 10.Slider.png
#14 Опубликовано: 25.10.2021 21:18:43
I think this can be a bug.
When a setting has a string value, it can not be read by canvas settings.
Delete the "TickPosition" = "both" and whatever will be readable again.
I have tried this with "orientation" = "vertical", whatever can't be read by canvas settings.
Deleted the "orientation" = "vertical" element, and it can be available again.
This behavior made me to think there is something wrong while reading strings.
#15 Опубликовано: 26.10.2021 05:58:20
Thank you, confirmed. I'll fix it ASAP.
You are right, it is related to strings encoding. If you remove the space character from "maximum value" it works as expected.
#16 Опубликовано: 01.11.2021 06:44:42
Issue fixed in both NumericUpDown and Slider regions for latest SS stable and later.
#17 Опубликовано: 01.11.2021 13:56:08
String issue not fixed, at least for linux.
slider_options.sm (4 КиБ) скачан 71 раз(а).
#18 Опубликовано: 02.11.2021 05:58:47
Thank you, I can reproduce with your file even in windows... this issue it's something more subtle, though
#19 Опубликовано: 02.11.2021 11:56:10
Found it. You forgot to set the optimization to "none" on definitions, as indicated in the documentation. If you hover over the definition you can see that in both numeric and symbolic optimization the boolean equal between strings is preprocessed and stored as 0.
#20 Опубликовано: 02.11.2021 14:28:13
Thanks, now it works.
To be honest I didn't read the documentation in first post.
I only looked in Reference Book and couldn't see that information in it.
