1 страниц (14 вхождений)
Text Region Utilities Plugin - Unable to install in 98.6128 - Сообщения
#1 Опубликовано: 12.10.2016 08:09:25
Davide Carpi 12.10.2016 10:36:00
#2 Опубликовано: 12.10.2016 10:35:31
thank you, I'll fix it ASAP
#3 Опубликовано: 12.10.2016 11:39:21
Davide, I've already fixed it by simple plug-in rebuild. Sorry, had no chance to inform you.
New version of the plug-in can be installed with no issues.
Davide Carpi 12.10.2016 12:30:00
#4 Опубликовано: 12.10.2016 12:12:15
Thank you Andrey and Davide for the fix.
#5 Опубликовано: 13.10.2016 00:45:45
The "insert a toolbox" in Text Region Utilities Plug-in exibit erratic behaviour.
1. It shifts the selected text to a new position.
2. Apparantly, the empty lines between text lines are also considered as text?
3. Had to press "Apply" more than once to convert all selected text.
Файл не найден. Файл не найден.
#6 Опубликовано: 13.10.2016 05:55:24
Thank you NDTM,
Fixing it, there were some changes in the API.
I'm not able to reproduce it; if you save the document with text regions and you load it again it still happens? If yes can you attach it here?
Wrote1. It shifts the selected text to a new position.
Wrote2. Apparantly, the empty lines between text lines are also considered as text?
#7 Опубликовано: 13.10.2016 10:24:20
I don't understand what a "Tool Box" could be ?
Smath 5346 "Text Box" allows lot of decoration.
Decoration for a Web page presentation for instance.
As an Engineering working document: decoration is
too much, IMHO.
Each Shift/Enter adds blank line(s), an empty space
where to slide: images, graphs, foreign text ...
too much, IMHO.
#8 Опубликовано: 13.10.2016 10:52:19
Thank you Davide!
The original file is attached; the problem still exists even after saving and re-opening.
Before Text Converter.sm (73 КиБ) скачан 85 раз(а).
Davide Carpi 13.10.2016 11:11:00
#9 Опубликовано: 13.10.2016 11:23:02
Wrotethe problem still exists even after saving and re-opening.
Thank you, is exactly what I was thinking. If you select all (CTRL+A) you can see some empty text region, probably created with an UNDO action (because my bad coding in the converter feature). Should be no more an issue with the coming plugin update (but if existing you have to remove them manually).
WroteI don't understand what a "Tool Box" could be?
Just a region that wraps some generic utilities related to the worksheet; when it will be possible I plan to move them in a toolbar (I'm working on it).
#10 Опубликовано: 13.10.2016 13:56:56
PLUGIN UPDATED
SMath Studio 0.98.6128
- fixed issues related to API changes;
- Text to Writer converter: history UNDO action managed correctly;
- Text to Writer converter: fixed hyperlink conversion;
- Batch hyperlinks: it is now possible to choose a path to investigate before launching the scan;
NDTM Amarasekera 13.10.2016 14:40:00
#11 Опубликовано: 13.10.2016 14:40:46
Thank you Davide for the update.
Davide Carpi 13.10.2016 15:00:00
#12 Опубликовано: 15.12.2016 14:43:38
#13 Опубликовано: 15.12.2016 15:22:31
Thank you Alex,
recompiled, try now.
sergio 16.12.2016 15:41:00
#14 Опубликовано: 16.12.2016 15:34:02
works fine now, thanks!
Новые сообщения
Нет новых сообщений
