Program for Linear and Polynomial Fit - Сообщения
#21 Опубликовано: 11.12.2019 13:31:21
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Опубликовано: 11.12.2019 19:05:16
WroteIf that's what you think.
Does it work for you ... SS 7251 users please confirm ?
#23 Опубликовано: 11.12.2019 21:25:41
WroteWroteIf that's what you think.
Hello Jean
Yes, It works
Carlos
#24 Опубликовано: 12.12.2019 00:09:00
WroteOriginally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
#25 Опубликовано: 12.12.2019 07:41:20
WroteThat's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
#26 Опубликовано: 12.12.2019 07:53:51
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
WroteWroteThat's my solution
Please check.
#27 Опубликовано: 12.12.2019 10:21:08
Wrotejust put the 1 into a 1x1 matrix. That's all.
Hi
Still the same error when n=0.
Better if you can post the SM file please.
#28 Опубликовано: 12.12.2019 11:21:42
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (11 КиБ) скачан 48 раз(а).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
sergio 12.12.2019 16:13:00
#29 Опубликовано: 12.12.2019 11:49:54
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
Cheers MarB.
#30 Опубликовано: 12.12.2019 13:06:39
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (46 КиБ) скачан 48 раз(а).
#31 Опубликовано: 12.12.2019 15:12:19
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (159 КиБ) скачан 57 раз(а).
PolyFit.pdf (748 КиБ) скачан 56 раз(а).
sergio 12.12.2019 16:12:00
#32 Опубликовано: 12.12.2019 15:15:52
Thank you, Alvaro.
Новые сообщения
Нет новых сообщений
