1 страниц (5 вхождений)
Incorrect values for rank - getting incorrect values using rank - Сообщения
#1 Опубликовано: 21.02.2013 10:57:28
I'm using SMATH for a controls class that I am taking. I am getting bad values for rank of a matrix.
A=[0,1;1,0]
should return a rank of 2
I keep getting a 1
A=[0,1;1,0]
I keep getting a 1
#2 Опубликовано: 21.02.2013 11:11:35
Seems that you defined A as a column vector. Depending on your settings, the comma serves as decimal point or as function argument separator.
type A:mat Enter
This gives you a 2x2 Matrix of placeholders.
type A:mat Enter
#3 Опубликовано: 21.02.2013 11:49:09
#4 Опубликовано: 21.02.2013 12:04:27
You have made an error defining Γ
You need to use the augment() function; without this function you create a nested matrix.
BTW there is a bug because calling directly the rank function when the first matrix element is a nested matrix, a type conversion error appears.
regards,
w3b5urf3r
rank.sm (11 КиБ) скачан 56 раз(а).
regards,
w3b5urf3r
#5 Опубликовано: 21.02.2013 12:07:37
Excellent, thanks to both of you.
Новые сообщения
Нет новых сообщений
