Temperature field
Temperature field - not straight line but one parabola - Сообщения
#1 Опубликовано: 15.07.2023 03:32:54
Valery Ochkov
Valery Ochkov
55 сообщений из 633 понравились пользователям.
I am trying to plot a temperature field in a three layer wall. There is no problem with the outer layers. But there is a problem in the middle layer - there should be a parabola, not a straight line. How to draw this parabola in the simplest way - with one formula. I know the hard way.
Stenka-3-eng.sm (60 КиБ) скачан 55 раз(а).
#2 Опубликовано: 15.07.2023 06:51:42
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
There are so many splines and Bezier interpolations in this forum!
But I don't understand why the connecting line has to be a parabola, because inside one wall layer the parameters (conductance, permeability) are constant so you should have only straight lines. Unless you found a way to have a gradual mix of material!!!
#3 Опубликовано: 15.07.2023 06:56:42
Valery Ochkov
Valery Ochkov
In the outer walls, the thermal conductivity does not depend on temperature, but in the middle wall it depends linearly!
#4 Опубликовано: 15.07.2023 07:17:49
Don't know if that is the simplest solution.
Stenka-3-eng.sm (58 КиБ) скачан 44 раз(а).
Valery Ochkov 15.07.2023 07:25:00
#5 Опубликовано: 15.07.2023 07:26:46
Valery Ochkov
Valery Ochkov
Fine!
And if the dependence of thermal conductivity on temperature is more complex, obtained, for example, through interpolation of discrete data. I would like to see an integral in the solution!
#6 Опубликовано: 15.07.2023 07:32:04
Version with mathcad block to collect the equations
Stenka-3-eng1.sm (59 КиБ) скачан 54 раз(а).
Valery Ochkov 15.07.2023 07:40:00
#7 Опубликовано: 15.07.2023 09:13:21
1. Three layers linear from min(x).
2. NON-linear from experimental
... project done Mathsoft Collaboratory.
Make the first & third segments linear.
The two documents sanity checked Smath Solver 30405.
Maths min(x),max(x).sm (22 КиБ) скачан 48 раз(а).
0Appendix_1 Thermal Insulation.sm (10 КиБ) скачан 47 раз(а).
#8 Опубликовано: 16.07.2023 05:40:21
Valery Ochkov
Valery Ochkov
One solution from Alan Stevens
Stenka-3-Alan.sm (60 КиБ) скачан 48 раз(а).
