1 страниц (4 вхождений)
Summation error - imaginary i as sum iterator - Changed summation behaviour? - Сообщения
#1 Опубликовано: 18.03.2018 17:55:24
Dear all,
Some years ago, I worked out a beam calculation tool in smath, based on singularity functions.
The sheet worked flawless in an older SMath version, but the most recent SMath-incarnations result in problems: the error seems to originate with the summation command.
How do I get this program working again?
I attach the original files: thanks for any feedback!
Kind regards from a Belgian SMath-fan,
Jan
Original file with summation error.sm (143 КиБ) скачан 64 раз(а).
Original file working.pdf (190 КиБ) скачан 76 раз(а).
Jan
#2 Опубликовано: 18.03.2018 18:25:11
janclaeys 19.03.2018 08:16:00
#3 Опубликовано: 19.03.2018 00:27:26
WroteHello.
This is because of using "i" as a variable.
Currently we have some issues regarding it.
Will be addressed soon.
Simple change to fix your worksheet:
Alternately: define the summations as local variable [SS 6179]
The document concludes the project.
Original file with summation error(1).sm (147 КиБ) скачан 63 раз(а).
#4 Опубликовано: 19.03.2018 08:16:29
Thank you Andrei & Jean for the fast feedback!
Новые сообщения
Нет новых сообщений
