"Not defined" Error - Why?
"Not defined" Error - Why? - Сообщения
#1 Опубликовано: 07.07.2021 03:17:13
Topaz
Topaz
Hello all,
please forgive me if the question is maybe ridiculous.
I want to use the symbolic solver with the maxima plugin, but when I write the equation I get the error that the variable a is not defined.This is correct, because I want to solve for this variable.
Therefore the question which mistake I make here?
#2 Опубликовано: 07.07.2021 03:50:03
Andrey
Andrey
1 сообщений из 44 понравились пользователям.
Hello all,
you must force-define the symbolic analysis through a pop-up menu
Davide Carpi 08.07.2021 07:38:00
#3 Опубликовано: 07.07.2021 09:52:06
maple is native in Smath for lot more with less trouble.
Contour Solve Isocurve DESCARTES.sm (41 КиБ) скачан 93 раз(а).
#4 Опубликовано: 07.07.2021 21:06:01
555 сообщений из 1333 понравились пользователям.
As andrbig77 said, you have to set optimization to symbolic.
Maxima plugin is powerful, but requires manual installation.
For information, involving these type of symbolic calculations;
Maple plugin could do the same with much less effort.
Just click and install from plugins menu, that's all.
