White Lines
White Lines - Plot Format - Сообщения
#1 Опубликовано: 25.10.2023 13:54:07
Valery Ochkov
Valery Ochkov
55 сообщений из 633 понравились пользователям.
I can only remove the blue lines by making them white.
Is this my defect or the SMath defect?
Points.sm (8 КиБ) скачан 57 раз(а).
#2 Опубликовано: 25.10.2023 17:29:12
You make your plot a segment of lines by using augment(X;Y).
Make every element individual if you want them as dots.
Valery Ochkov 25.10.2023 19:54:00
#3 Опубликовано: 25.10.2023 17:54:06
Is this my defect or the SMath defect ?
I use this feature commonly.
#4 Опубликовано: 25.10.2023 18:36:23
You can set the line color of any trace (input object) to transparent:
Valery Ochkov 25.10.2023 19:53:00
#5 Опубликовано: 26.10.2023 02:07:16
When it is possible, I would only use 2D plot.
X-Y plot is superior, but most times not needed.
Valery Ochkov 26.10.2023 02:39:00, NDTM Amarasekera 26.10.2023 14:40:00
