1 Pages (10 items)
How can I use not a for but a while cycle? - Messages
#1 Posted: 2/9/2024 9:27:16 PM
See please the attached file.Newton.sm (23 KiB) downloaded 59 time(s).
#2 Posted: 2/9/2024 11:38:00 PM
Greetings,
Instead of using for(3); you can use for(4):
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
example:
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
for ▮, ▮, ▮
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
k:=2*i
k:=2*i
Valery Ochkov 2/10/2024 2:37:00 PM
#3 Posted: 2/10/2024 2:38:31 PM
#5 Posted: 2/11/2024 1:58:11 AM
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52 KiB) downloaded 52 time(s).
Valery Ochkov 2/11/2024 2:13:00 AM
#6 Posted: 2/11/2024 2:53:28 AM
#7 Posted: 2/11/2024 7:55:50 AM
Wroteoots vs Newton
No interest vs the codes
#8 Posted: 2/11/2024 1:41:06 PM
#9 Posted: 2/11/2024 9:59:12 PM
#10 Posted: 2/13/2024 6:19:59 AM
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16 KiB) downloaded 58 time(s).
Alvaro Diaz Falconi 2/29/2024 12:13:00 PM
1 Pages (10 items)
New Posts
No New Posts
