Beta: SMath Studio 0.99.7666 (27 December 2020) - Messages
Changes introduced in current build 0.99.7666
Improvements
- Support to format content fragments added in Text Region (font size, font family, font weight; font style, text decoration, text color, background color, lines interval, paragraphs in Document mode);
- Added possibility to restore automatic line breaks mode in Text Region by doubleclick on resizer.
Corrections
- Critical error happened sometimes when using Del keyboard button in Math Region fixed.
Miscellaneous
- Smart auto replacement functionality implemented for Text Region in Document Mode (f.e. inserting --- finalized by Enter will be replaced with horizontal rule; filling in equation in text will be detected as well);
- Horizontal/vertical align toolbar buttons made hidden in Document mode;
- Refactoring.
Download
SMathStudioDesktop.0_99_7666.Mono.tar.gz (1 MiB) downloaded 792 time(s).
SMathStudioDesktop.0_99_7666.Setup.msi (2 MiB) downloaded 2550 time(s).
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region.
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
paste.sm (3 KiB) downloaded 74 time(s).
WroteBTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description.
Hello Alvaro.
Thank you! Will fix it asap.
Thanks,
Jason
WroteI'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error.
The reason of this error is the same as it is in the issue [USERLINK]Razonar[/USERLINK] mentioned above. Fixed now.
New Posts
No New Posts
