Issues with cases/if and error()
Issues with cases/if and error() - Messages
#1 Posted: 6/21/2023 9:48:32 AM
Arie
Arie
93 likes in 285 posts.
I am having some strange issues with cases/if statements that contain variables in the condition in addition to error() function in the result.
The issue only arises when the if/cases statements are in a function that is passed into another function. See attached.
Any thoughts?
variablesInConditions.sm (14 KiB) downloaded 75 time(s).
variablesInConditions.pdf (88 KiB) downloaded 79 time(s).
#2 Posted: 6/21/2023 10:21:42 AM
983 likes in 6866 posts.
#3 Posted: 6/21/2023 10:28:04 AM
Arie
Arie
This is certainly a workaround. Something I could do and perform error handling at the next level.
I'm more curious is this is an actual bug or if I'm doing something incorrectly.
#4 Posted: 6/21/2023 10:34:42 AM
Your function of function complains about the code as bug.
Will come back ... time to seed bean !
#5 Posted: 6/21/2023 12:17:52 PM
No more red, I don't understand the project.
variablesInConditions.sm (19 KiB) downloaded 67 time(s).
#6 Posted: 6/21/2023 2:07:36 PM
1417 likes in 2873 posts.
Hello, this is expected. By design because framework constraints, not by will, but it is the only way to have the function working in some contexts like inside integrals and such.
In case of numerical evaluation of the conditions, like in the if(...) function, the single cases are "sealed" from evalution up to when the conditions are actually evaluable. In cases(...) everything is always exposed to evaluation (and that's why you shouldn't use assignments inside the single cases). Hence, since error() is evaluated, it throws the error message.
Arie 6/21/2023 2:22:00 PM
#7 Posted: 6/21/2023 2:25:34 PM
Arie
Arie
Hi Davide,
Thanks for the explanation. I think I understand why cases(...) will not work. But I still receive a strange error when using if(...). Is this also expected?
variablesInConditions.sm (15 KiB) downloaded 66 time(s).
#8 Posted: 6/23/2023 10:33:15 AM
Hi, sorry the late answer!
Yes, altough I'm not sure if could be improved by Andrey somehow.
With some slight modifications on the names, you can see more clearly that the error is generated on the F1(2) preprocessing. Here x is passed as input to the first argument and if() fires the error.
The only alternative that comes to my mind right now is the one below. You have to pass the function name rather than the function itself.
It is a workaround, and if you pass it as a variable, the variable itself must be not defined.
variablesInConditions_alt1.sm (11 KiB) downloaded 70 time(s).
(The attachment has a more complicated function just to make the string input independant from localization settings)
Arie 6/23/2023 2:29:00 PM
#9 Posted: 6/23/2023 2:03:50 PM
More instances of if/otherwise failed in program.
if/otherwise does not belong to the Smath kernel.
#10 Posted: 6/23/2023 3:07:13 PM
Arie
Arie
Thanks Davide!
This workaround will suffice for me.
Davide Carpi 6/25/2023 7:10:00 AM
  • New Posts New Posts
  • No New Posts No New Posts
