Find rows of matrix
Find rows of matrix - Boolian Test - Messages
#1 Posted: 6/26/2023 2:59:27 PM
RegRetired
RegRetired
8 likes in 130 posts.
How do I find all rows of a matrix M where column n contains all numbers ≤ x.
I cannot figure out how to use findrows for this. If my text expression is max(M) it works fine, but
the ≤ test does not work for me.
An example would be much appreciated.
Reg Curry Loveland, CO
#2 Posted: 6/26/2023 3:11:42 PM
RegRetired
RegRetired
Oops, I meant test expression, not text expression.
#3 Posted: 6/26/2023 5:24:48 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. This is an option.
MFind.sm (14 KiB) downloaded 82 time(s).
MFind.pdf (58 KiB) downloaded 101 time(s).
NDTM Amarasekera 6/27/2023 7:38:00 AM
#4 Posted: 6/26/2023 5:56:46 PM
RegRetired
RegRetired
Great! Thanks for all your help.
#5 Posted: 6/27/2023 12:13:11 PM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Another method
Array_Pos.sm (14 KiB) downloaded 61 time(s).
#6 Posted: 6/27/2023 2:51:06 PM
RegRetired
RegRetired
Ndtma,
Thanks; however, I don’t understand the large numbers in your answer, which are greater than the size of the matrix.
Sorry for my lack of understanding.
#7 Posted: 6/27/2023 4:48:45 PM
1417 likes in 2873 posts.
Ndtma,
It's the item position by linear indexing. Elements can be accessed using a single index, that is the position sorted by rows (base 1). f.e. The 2nd element in the 3rd row is indexed (3-1)*cols(matrix)+2
#8 Posted: 6/27/2023 5:41:12 PM
RegRetired
RegRetired
Okay, thanks. More complicated than I was looking for. My matrix is 2000x2. But, the responses gave me a clue on how to write my own that is similar to the MATHCAD match function.
Because PTC no longer supports MATHCAD 15 and the future of getting a new license if my computer fails is in question, SMATH is a lifesaver. I am gradually converting my important files to SMATH. SMATH is a real service and excellent option for those in my situation.
I am gradually becoming accustomed to SMATH. I do have one more question on plots. If I click in an XY plot to change some formatting and I accidentally hit my mouse wheel, the plot changes the zoom level. It’s not obvious how to return to the original view. If I close the file and reopen, it is back to normal. At first I thought this was a bug, but searching the forum, I see it is a feature. Is there a simple way to return to the original view when I accidentally move my mouse wheel.
Thanks again.
#9 Posted: 6/27/2023 6:16:02 PM
983 likes in 6866 posts.
I am gradually becoming accustomed to SMATH.I do have one more question on plots.If I click in an XY plot to change some formatting and I accidentally hit my mouse wheel, the plot changes the zoom level.It’s not obvious how to return to the original view.If I close the file and reopen, it is back to normal.At first I thought this was a bug, but searching the forum, I see it is a feature.Is there a simple way to return to the original view when I accidentally move my mouse wheel.
I mentioned that before, about your spoiled X_Y plot
f(x), data ... quick plot is insensitive to command wrt the graph plot.
Differently the X_Y plot will scrap the limits if you slide the graph.
Never put the mouse in the X_Y plot. Resize [X,Y] from the system.
#10 Posted: 6/27/2023 6:53:46 PM
554 likes in 1333 posts.
Thanks again.
You can try to learn setprop() function for X-Y Plot.
https://en.smath.com/forum/yaf_postst1774_X-Y-Plot-Region.aspx
https://en.smath.com/forum/yaf_postsm59088_X-Y-Plot-Region.aspx#post59088
Here is a simple demonstration I posted before.
DPT_NV plot.sm (20 KiB) downloaded 66 time(s).
#11 Posted: 6/27/2023 7:42:06 PM
RegRetired
RegRetired
Thanks. Very helpful!
  • New Posts New Posts
  • No New Posts No New Posts
