Symbolic resolution from mathcad to SMath-Studio
Symbolic resolution from mathcad to SMath-Studio - symbolic resolution from mathcad to SMath-Studio - Messages
#1 Posted: 8/31/2021 4:23:02 PM
Erick Valentino
Erick Valentino
7 likes in 28 posts.
How can I do a symbolic resolution in SMath-Studio?
In mathcad there are: simplify, expand, substitute, etc.
When I solve an equation, I have to use "maple". Can this be done without using it?
Mathcad to SMath Studio.sm (103 KiB) downloaded 94 time(s).
#2 Posted: 8/31/2021 4:52:14 PM
Arie
Arie
93 likes in 285 posts.
The built in symbolic engine in SMath leaves much to be desired.
I know the maple plugin has at least some of the functionality you're looking for. Also you'll want to check out the Maxima plugin as that's very useful for solving symbolic equations as well.
#3 Posted: 8/31/2021 7:34:42 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 likes in 1676 posts.
Hi Valentino. This is a way.
Mathcad to SMath Studio.sm (102 KiB) downloaded 183 time(s).
Erick Valentino 8/31/2021 8:32:00 PM
#4 Posted: 8/31/2021 8:00:34 PM
983 likes in 6866 posts.
In Mathcad there are: simplify, expand, substitute, etc.
Most Mathcad command line work as well in Smath.
ODE Maple Example Copy.sm (118 KiB) downloaded 121 time(s).
#5 Posted: 9/1/2021 9:16:33 AM
... augmented version.
ODE Maple Example Copy.sm (134 KiB) downloaded 105 time(s).
#6 Posted: 9/1/2021 4:40:43 PM
555 likes in 1333 posts.
Maple and Maxima plugins has symbolic simplify functions.
Unfortunately SMath don't have this features natively.
#7 Posted: 9/1/2021 6:36:42 PM
Which of these 6 styles do you prefer ?
Mathematica has a long discours on that .
#8 Posted: 9/1/2021 7:01:18 PM
You can write your own functions to make expand(),simplify() work as if they are implemented.
Don't sure if they will work with complicated function, but they are fine with simple ones.
#9 Posted: 9/1/2021 8:05:05 PM
Erick Valentino
Erick Valentino
Alvaro thank you very much, your solution has worked very well for me. I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement?
#10 Posted: 9/1/2021 8:09:47 PM
Erick Valentino
Erick Valentino
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Conver" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for?
#11 Posted: 9/1/2021 8:18:08 PM
Erick Valentino
Erick Valentino
How did you put so many "boolean equals" without the parentheses being uncertain?
¿Cómo pusiste tantos "iguales booleanos" sin que los paréntesis sean inciertos?
Thank you
#12 Posted: 9/1/2021 8:59:49 PM
From an old Mathcad/Mathsoft contest.
#13 Posted: 9/1/2021 9:05:48 PM
Jean thank you very much for sharing your examples, they are great. I have a question, you use commands like "Convert" "Collect" "dsolve" and "invlaplace" but they don't appear in "all my functions"; The program executes the commands but it does not allow me to see their description or know what they are for, are they from a complement? what are they for ?
They just make the demand produce/solve.
Few more attached as you may need eventually.
Cheers Valentino ... Jean
Symbolic Convert Parfrac Primary FNCTS.sm (118 KiB) downloaded 98 time(s).
#14 Posted: 9/1/2021 9:36:51 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
...I have a question, you use commands like "Collect" and "Opt" but they don't appear in "all my functions"; ...
Opt = Symbolic or Opt = None means that you must to right click over an expression, and choose Optimization / Symbolic or None, not a command.
About collect and other expression they aren't from SMath, but from Maple plugin, which is Maple version 6. So, you must to learn something about it. Maplesoft online help could be very extended: Maple help but you can also read some good manuals like "Aprenda Maple 8 como si estuviera en primero" from Universidad de Navarra (you can google it, it's free). Just a notice: Maple V have several differences about how handle strings and some other things, so if you can't find a good short manual about Maple 6 try only up versions.
#15 Posted: 9/1/2021 9:45:04 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
With some hard work you can hack the SMath syntax: From https://en.smath.com/forum/yaf_postsm56111_Some-future-requests.aspx#post56111
HackingEqual.sm (3 KiB) downloaded 157 time(s).
overlord 9/2/2021 11:23:00 AM
#16 Posted: 9/1/2021 9:48:40 PM
The continued fractions are not futile ... Explain.
Before the modern CAS, the main frame IBM, used continued fractions.
As well as the J_Fraction... Where is my Mathcad on that ?
Since then, the Padé normalized fractions have replaced
the continued fractions, more stable numerically, faster parallel.
#17 Posted: 9/1/2021 10:12:27 PM
... Expand options
#18 Posted: 9/1/2021 10:21:44 PM
... matter of preference.
Expand.sm (13 KiB) downloaded 86 time(s).
#19 Posted: 9/2/2021 9:03:30 AM
... more for your bed time reading, Valentino !
Smath is not envious of PTC_Mathcad ... Jean.
Inst_TurboGen Smath [SHORT].sm (19 KiB) downloaded 79 time(s).
Inst_TurboGen Signum.sm (86 KiB) downloaded 78 time(s).
Inst_TurboGen Smath.sm (118 KiB) downloaded 85 time(s).
#20 Posted: 9/2/2021 11:24:40 AM
With some hard work you can hack the SMath syntax.
This is nice. I didn't know it could be done.
Formulas work even after brackets removed.
Not just a cosmetic removal.
Thanks a lot.
  • New Posts New Posts
  • No New Posts No New Posts
