Wrong unit for (variable with units)^number
Wrong unit for (variable with units)^number - Messages
#1 Posted: 5/20/2023 2:50:55 AM
JP
JP
0 likes in 6 posts.
I have:
x=number (inches)
A=x^-number
A= decimal number.fraction (unit)
Why am I getting a results that is a product of decimal and fraction rather than a decimal or fraction?
The unit seems to be only for the fraction.
I am not sure how to paste my results from SMath Studio.
#2 Posted: 5/20/2023 3:06:10 AM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
I have:
x=number (inches)
A=x^-number
#3 Posted: 5/20/2023 4:11:14 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
I have:
x=number (inches)
A=x^-number
A= decimal number. Fraction (unit)
Why am I getting a results that is a product of decimal and fraction rather than a decimal or fraction? ...
Because that's the correct answer:
... The unit seems to be only for the fraction. ...
Powering units could be some confuse, but don't worry, more confusing could be check the SI official standard about how to write it.
#4 Posted: 5/20/2023 10:01:30 AM
JP
JP
0 likes in 6 posts.
How do I ignore the units for x=7 in when used in the A=x^2 formula?
I tried 'ignore units' and it did not change anything.
Thanks!
#5 Posted: 5/20/2023 12:20:31 PM
983 likes in 6866 posts.
How do I ignore the units for x:=7
Type 7 ... multiply ... type ' [apostrophe]
In the round place holder ... Units inch
#6 Posted: 5/20/2023 2:26:15 PM
Originally Posted by: Jean Giraud [url=/forum/yaf_postsm81315_Wrong-unit-for--variable-with-units-number.aspx#post81315][/url]Type 7 ... multiply ... type ' [apostrophe]
Does it work as you demanded ?
#7 Posted: 5/20/2023 3:02:47 PM
554 likes in 1333 posts.
Never do this, Razonar's approach is the correct one.
Jean is simply against SI units, don't listen to him for anything involved units.
And never ever use Jean's engineering calculations for anything.
They are notorious for being wrong and giving false results.
If he insists at anytime about using SMath 0.99.6179, simply ignore it.
That is a 6+ year old version of SMath, always use latest stable.
Alvaro Diaz Falconi 5/20/2023 6:34:00 PM
#8 Posted: 5/20/2023 6:27:54 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
How do I ignore the units for x=7 in when used in the A=x^2 formula? ...
Hi. Something like this?
#9 Posted: 5/21/2023 5:32:01 PM
JP
JP
0 likes in 6 posts.
@Razonar
Not sure. If I use 'A' in another equation, will it consider the units for A?
I dont what it to as it will mess up the units for that answer...which will mess up the units for the subsequent equation.
#10 Posted: 5/21/2023 7:12:35 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
The choice as to whether you want to use A with or without units is yours. You can use the version of A with units, or the version of A without units. But not both at the same time.
#11 Posted: 5/22/2023 6:49:46 AM
1222 likes in 2150 posts.
I have:
x=number (inches)
A=x^-number
Such problems usually emerge if you have an equation where the variables aren't meant to be numerical values of quantities given in a particular unit rather than being real physical quantities (number times unit).
SMath is designed for work with quantity times unit variables. If you want to use an empirical equation, you also must provide the units of each variable (be it input or result).
You can integrate such equations into a world of proper handling of physical quantites by dividing each input parameter by the unit in which it is supposed to be inserted and by multiplying the expression by the unit in which the result is supposed to be given by that empirical model.
Worksheet2.sm (5 KiB) downloaded 43 time(s).
Alvaro Diaz Falconi 5/22/2023 11:36:00 AM
#12 Posted: 5/22/2023 11:35:24 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... You can integrate such equations into a world of proper handling of physical quantites by dividing each input parameter by the unit in which it is supposed to be inserted and by multiplying the expression by the unit in which the result is supposed to be given by that empirical model.
That is a very smart recommendation.
  • New Posts New Posts
  • No New Posts No New Posts
