load a file .sm win10 and linux
load a file .sm win10 and linux - error on linux - Messages
#1 Posted: 4/26/2021 5:22:16 PM
philippe dalet
philippe dalet
18 likes in 34 posts.
I can load a .sm file on Windows 10 (see joined files), but I have a big problem on linux (Ubuntu 20.04 64 bits - mono 6.12.0.122).
When I have loaded the file .sm, all menus disappears and the sheet displayed becomes bigger .
tested with
smathstudio 0.99 build 7786 and build 7778
Thanks a lot.
Philippe DALET.
#2 Posted: 4/26/2021 5:58:07 PM
2271 likes in 3734 posts.
Please could you attach a screenshot from Linux?
#3 Posted: 4/26/2021 6:59:21 PM
philippe dalet
philippe dalet
philippe
Andrey Ivashov 4/26/2021 7:42:00 PM
#4 Posted: 4/26/2021 7:15:06 PM
554 likes in 1333 posts.
Nothing is wrong with my setup.
#5 Posted: 4/26/2021 7:42:52 PM
Thank you. Will check this issue.
#6 Posted: 4/27/2021 5:20:18 AM
philippe dalet
philippe dalet
Hello Andrey ,
I run smathstudio on a terminal and no error messages are displayed in the terminal.
- [AppDir] PictureRegion 1.10.7786.571 (21 ms.)
- [AppDir] SpecialFunctions 1.12.7786.571 (21 ms.)
- [AppDir] StandardToolboxButtons 1.1.7786.571 (0 ms.)
- [AppDir] TextRegion 1.11.7786.571 (10 ms.)
- [AppDir] PlotRegion 1.11.7786.571 (11 ms.)
- [AppDir] HTMLFileType 1.14.7786.571 (1 ms.)
- [AppDir] XMCDFileType 1.12.7786.571 (3 ms.)
- [AppDir] AreaRegion 1.11.7786.571 (2 ms.)
- [AppDir] SMathFileType 1.11.7786.571 (1 ms.)
- [AppDir] ImageFileType 1.11.7786.571 (1 ms.)
- [AppDir] MathRegion 1.11.7786.571 (2 ms.)
- [AppDir] ViewerFileType 1.1.7786.571 (2 ms.)
I have done the same operation with SMathStudioDesktop.0_99_7691.Mono.
All is OK. No errors.
Ph.D
#7 Posted: 4/27/2021 2:22:39 PM
philippe dalet
philippe dalet
Philippe,
If you don't mind, attach the *.sm document.
Will add to my Instrumentation Compendium.
I have Pt, T, J advanced thermometers but not alcohol column.
Thanks ... Jean.
Thanks
The file is a correction of a physical problem given to my students.
File not found.File not found.File not found.
#8 Posted: 5/9/2021 5:36:10 AM
philippe dalet
philippe dalet
Hello Andrey,
I have found the origin of the bug.
In text region (only on linux)
changing
with
eliminates the bug.
no bug on Win10
ph.D
Andrey Ivashov 5/9/2021 7:11:00 AM
#9 Posted: 5/9/2021 7:44:28 AM
Hello.
changing
with
eliminates the bug.
Please could you try to replace "Arial" with some another Font name installed on your system? Unfortunately I cannot reproduce a bug, but maybe it is because Arial is not available on your system?
If other fonts will work I think I could try to fix this problem.
#10 Posted: 5/9/2021 7:32:42 PM
philippe dalet
philippe dalet
Hello.
changing
with
eliminates the bug.
I have install Arial fonts on ~/.fonts folder, and the display is correct.
All is OK
Thanks.
philippe
  • New Posts New Posts
  • No New Posts No New Posts
