Least squares method
Least squares method - Least squares method with option to select the power of the polynomial - Messages
#1 Posted: 4/26/2019 12:06:13 AM
CBG
CBG
77 likes in 312 posts.
Another example of curve fitting by the least squares method
with option to select the power of the polynomial, or
select the adjustment of the curve to exponential or potential.
Ajust_by_Last_Square_Selection_Jean.sm (56 KiB) downloaded 174 time(s).
Carlos
5 users liked this post
frapuano 4/26/2019 4:12:00 AM, sergio 4/26/2019 5:33:00 AM, NDTM Amarasekera 4/26/2019 7:20:00 AM, Arie 4/26/2019 9:38:00 AM, Davide Carpi 4/28/2019 5:56:00 AM
#2 Posted: 4/26/2019 10:40:32 AM
983 likes in 6866 posts.
Hola Carlos !
Couldn't open the attached SS 7030 work sheet.
It happened another time from maybe Alvaro ?
Seemingly caused by 2 of your modules not activated.
My SS 6179 does not closed those two particular modules.
However, I have recognized the flat parabola data set.
I'm sure your proposal will have more applications.
Data sets with flat region best fit by model function,
like this one from al_nleqsolve, always assumed noisy.
Two flat parabolas attached
Thanks... Cheers ... Jean
Genfit [Algo Minimize(Cholesky_3 NonLinear)].sm (37 KiB) downloaded 98 time(s).
Genfit al_ nleqsolve [Edu Model FLAT Parabola].sm (30 KiB) downloaded 87 time(s).
#3 Posted: 4/26/2019 2:18:39 PM
CBG
CBG
Hola Carlos !
Hola Jean
Here you have a version in 6179 of the work sheet
of the method of adjustment of curves by least squares
Ajust_by_Last_Square_Selection_Jean_V6179.sm (52 KiB) downloaded 117 time(s).
Cheers
Carlos
#4 Posted: 4/29/2019 11:02:17 AM
Hola Carlos.
Thanks for your contribution, most appreciated. More bed time reading.
VISITORS: download all, as they are minimalist Fit Classroom.
One more method is not listed wrt Polynomial fit: the Robert lsq.
Problem is that I can't make it work Mathcad ORIGIN (1)
Next Classroom is large as applied to a large collection of applied projects.
This next Classroom is mostly based on fitting parametric model function(s)
Genfit 0 Ge SubCryogenic.sm (38 KiB) downloaded 80 time(s).
Genfit 00 Carlos-Cholesky.sm (37 KiB) downloaded 80 time(s).
Genfit 0000 Adjust Linear.sm (49 KiB) downloaded 75 time(s).
Genfit 000000 LinfitCheby.sm (77 KiB) downloaded 78 time(s).
Genfit 00000 Linfit Linear.sm (32 KiB) downloaded 75 time(s).
Genfit 000Carlos.sm (45 KiB) downloaded 73 time(s).
Genfit 00000000 PolyOrder.sm (25 KiB) downloaded 91 time(s).
Genfit 000000000 Thiele Corn Thermies.sm (44 KiB) downloaded 77 time(s).
Genfit 0000000 Rational Auto-init ITER.sm (84 KiB) downloaded 78 time(s).
Genfit 0000000000 Rational Num_Denom Order.sm (77 KiB) downloaded 78 time(s).
#5 Posted: 4/30/2019 11:32:23 AM
... a must visit suite.
Three examples most useful for Engineering/Scientific
1. DE sol is intuitive of attempting a fit to your DE
2. Corn Thermies is more local agriculture
3. HadCRUt4 is most advanced Scientific.
So much BS & BK on that blabla parrot
BS & BK => from my old friend Ken [Bull Shit & Book Keeping].
Former Collab Theodore tried all possible orthogonal polynomials,
not to avail vs ChebyShev [I guess Russian does not lie]
Genfit 00000000000 LinfitCheby Order [DE sol].sm (30 KiB) downloaded 89 time(s).
Genfit 00000000000 LinfitCheby Order [Corn Thermies].sm (30 KiB) downloaded 77 time(s).
Genfit 00000000000 LinfitCheby Order [HadCRU].sm (193 KiB) downloaded 72 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
