Clipboard Region
Clipboard Region - Messages
#1 Posted: 9/26/2013 8:32:23 PM
1417 likes in 2873 posts.
SMath up to 0.96.4909 > password: test
SMath 0.97.5301 or later >
link a variable in the placeholder and left-click on the region to export the variable to the clipboard (clipboard's content can be pasted in spreadsheets or text editors - can't be used as variable in SMath)
Also, you can paste spreadsheets data directly in the region placeholder.
PLEASE REPORT HERE ANY ISSUE
Best regards,
Davide
ioan92 9/27/2013 3:59:00 AM, Radovan Omorjan 9/27/2013 12:09:00 PM, Mark R Harris 9/5/2022 1:16:00 AM
#2 Posted: 9/27/2013 10:36:27 AM
sublim21
sublim21
3 likes in 36 posts.
looking great websurfer. Looks like you're all about the extensions now.
#3 Posted: 9/27/2013 12:13:04 PM
325 likes in 2052 posts.
Thanks Davide
Try to reproduce this one
A:=something(2)
where something() is not defined. This will crash Smath for me.
Davide Carpi 9/28/2013 10:18:00 AM
#4 Posted: 9/27/2013 12:22:55 PM
Thank you both, I'll check the issue
Btw as I've written in another topic I hope that a "copy special" and a "paste special" will be implemented natively in smath, from context menu (and maybe from shortcuts, like ctrl+ shift +c to make the "external copy" )". Since that day I hope this plugin will help.
#5 Posted: 9/28/2013 10:17:25 AM
Thanks Davide
A:=something(2)
fixed & updated
[edit] working to add both import and export features
Radovan Omorjan 9/28/2013 1:48:00 PM
#6 Posted: 9/29/2013 8:54:33 AM
UPDATED
- added "import data"
#7 Posted: 3/10/2014 3:30:22 AM
experimentator
experimentator
1 likes in 21 posts.
After installing the ClipboardRagion pluging Smath displays the error as follows.
I have neither the possibility of deleting nor re-installing.
Learning by doing
#8 Posted: 3/10/2014 3:59:22 AM
1222 likes in 2150 posts.
Just search for the dll and remove the associated folder structure, typically "some cryptic name/some version number". Currently that is the only way to remove plugins.
It may help to locate the settings directory using the function SettingsDirectory(). There you find folders extensions/plugins, where the above-mentioned plugin directories reside.
#9 Posted: 3/10/2014 4:24:30 AM
experimentator
experimentator
Danke Martin, it works, but I cannot install the extension again, occurs the same problem.
Learning by doing
#10 Posted: 3/10/2014 4:45:58 AM
That's because the Clipboard Region plugin has not yet been updated to SMath Studio 0.97 (there were API changes). Also there might be problems in actually doing the update (Davide reported problems with clipboard handling).
Davide Carpi 3/10/2014 6:41:00 AM
#11 Posted: 3/10/2014 6:45:02 AM
Exactly, as for now this plugin works only with SMath up to 0.96.4909; a new plugin will be relased when Andrey will fix the issues in the clipboard interface.
Best regards,
Davide
#12 Posted: 5/10/2014 10:06:51 AM
Don't know exactly what is the default behavior for plugins uploaded before the introduction of the target version in the Extensions Menager, this plugin should be not visible; anyway it is just a transitory issue...
ioan92 5/10/2014 10:25:00 AM
#13 Posted: 7/14/2014 4:00:08 AM
UPDATED SMath 0.97.5301
- Updated to fit recent API changes;
- fixes;
- New features: paste inside placeholder;
Be sure to have the "Exclude beta-versions" unchecked
ioan92 7/14/2014 4:55:00 AM, sergio 7/14/2014 4:31:00 AM
#14 Posted: 8/26/2022 6:20:27 AM
Reiltar
Reiltar
0 likes in 2 posts.
Hi all,
First of all, sorry for reopening such an old topic but.... hasn't anybody had an issue then trying to import to smath negative values from excel?
Maybe it's related with revision changes in both smath and excel, but when I have negative values I get them imported as text, between quotes "-0.534" i.e
any idea about how to solve that?
Thanks,
#15 Posted: 8/29/2022 1:18:42 PM
I'll check it, thank you for reporting the issue.
sergio 8/29/2022 3:57:00 PM
#16 Posted: 8/29/2022 3:01:06 PM
983 likes in 6866 posts.
"-0.534" i.e
In the mean time it will doctored otherwise.
#17 Posted: 8/29/2022 3:36:19 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Hi Davide. Related, though not exactly a plugin question. But since you are going to see the question of the sign in strings, do you know how to specify a negative exponent inside SMath, as in the following example?
Thanks in advance.
churichuro 8/29/2022 8:02:00 PM, sergio 8/29/2022 3:57:00 PM
#18 Posted: 8/29/2022 8:01:31 PM
churichuro
churichuro
28 likes in 79 posts.
Alvaro an alternative way is
while a better solution is given.
sergio 8/30/2022 6:19:00 AM, Alvaro Diaz Falconi 8/30/2022 12:32:00 AM
#19 Posted: 8/30/2022 12:36:17 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Churichurro. Thanks, it is a very good workaround, it works, substituting str2num(strrep(STR,"E-","*10^-" ) )
#20 Posted: 9/1/2022 9:25:12 AM
Reiltar
Reiltar
0 likes in 2 posts.
"-0.534" i.e
Thanks for this temporary solution.
  • New Posts New Posts
  • No New Posts No New Posts
