[XlsxImportExport] Exporting Matrix into xlsm File - Exporting a Matrix and exporting into xlsm file of excel - Messages
#21 Posted: 10/28/2018 5:53:31 AM
Wrotedont understand what you mean.
WroteIf I use your first SMath Studio worksheet with the latest workbook it seems to work for me.
smath worksheet from post #1: Test_#1.sm (8 KiB) downloaded 52 time(s).
excel workbook from post #18: Wallthickness.xlsm (93 KiB) downloaded 54 time(s).
This works for me.
WroteIn your latest worksheet
- first import function name ends with "M" instead of "X" in the subscript that is a function not defined
In post #18 you changed the content of the SMath worksheet.
This is the typo I was talking. As you correctly wrote in first post, it should be:
Wrote- in second import the column A of the excel worksheet returns several circular reference exceptions (there aren't stored values even opening it with excel and the plugin isn't able to calculate one... I might return 0 or the cell formula...)
This is the new range you are trying to import in the SMath worksheet #18. The range rewritten top-left:bottom-right is A5:G150. The plugin fails loading the first column (I see a circular reference exception in the debugger, thrown by the ClosedXML library), that is something I'll look into.
#22 Posted: 10/28/2018 7:27:14 AM
Thank you! Best regards!
New Posts
No New Posts
