Curve fitting function
Curve fitting function - Is there a curve fitting function in Smath? - Messages
#1 Posted: 1/13/2022 7:38:26 AM
rex
rex
1 likes in 10 posts.
Is there any curve fitting function in Smath?
I mean using the defined points to find the function of these points!
Thanks a lot!
#2 Posted: 1/14/2022 12:00:26 AM
rex
rex
... for best examination: close Smath ... open a virgin session.
This way, as you will download, both will be resident in same session.
Open include to inspect the content, close back.
Open Test UpDated ... F9 to run
Test Updated contents 5 stand alone fit examples.
If it does not work wrt your Smath version ... bug.
Try it ... report ... Jean
Genfit Algo Include.sm (36 KiB) downloaded 92 time(s).
Genfit Algo Include Test UpDated.sm (145 KiB) downloaded 85 time(s).
Hi Jean,
Thanks for your reply!
I tired the .sm file, but it doesn't work well. Meanwhile, the Genfit Algo Include.sm needs rename as GenfitAlgoInclude.sm.
I put the two .sm files in the same location, tSmath_error.pnghen I opened the Test Updated.sm, and pressed F9 to run....the error is shown in the picture.
The information of my Smath is Version 0.99
Looking forward to your feedback, thanks!
[attach]42964
#3 Posted: 1/14/2022 12:53:11 AM
CBG
CBG
77 likes in 312 posts.
Hello
Maybe you can deal with Least Squares Fit
Define_a_Variable_Ajust_by_Last_Square.sm (58 KiB) downloaded 120 time(s).
Ajust_by_Last_Square_Selection.sm (54 KiB) downloaded 88 time(s).
Carlos
#4 Posted: 1/14/2022 2:04:40 AM
555 likes in 1333 posts.
Answer is YES
I don't know an embedded function for this.
But you can write your own function.
Lagrange Interpolation Method can be used.
maple() command is not necessary but it simplifies the function.
Giving more points, curve gets more complex.
Here is some examples for your request.
lagrange.sm (26 KiB) downloaded 95 time(s).
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
sergio 1/14/2022 6:15:00 AM, Alvaro Diaz Falconi 1/14/2022 4:19:00 PM
#5 Posted: 1/14/2022 2:55:13 AM
rex
rex
Hello
Carlos
Hi Carlos,
This works really fine, thanks for sharing this!
#6 Posted: 1/14/2022 2:57:10 AM
rex
rex
Answer is YES
Click to enlarge
Click to enlarge
Click to enlarge
Click to enlarge
Hi, thanks for sharing this, I will try to learn your file!
#7 Posted: 1/14/2022 5:36:56 AM
1230 likes in 2155 posts.
Thanks a lot!
Maxima plugin has the Fit() function, see this post
In the interactive handbook, you find it in the Function Index page.
#8 Posted: 1/14/2022 6:56:58 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 likes in 1676 posts.
Hi. Some fitting curves functions in the attached.
fit.pdf (527 KiB) downloaded 132 time(s).
fit.sm (377 KiB) downloaded 108 time(s).
NDTM Amarasekera 1/14/2022 11:23:00 AM, sergio 1/14/2022 7:23:00 AM, Fridel Selitsky 1/14/2022 7:26:00 AM
#9 Posted: 1/14/2022 10:56:33 AM
You are welcome.
My function is direct method, may not be suitable for large data sets.
Razonar's and mkraska's samples are good to investigate too for that purpose.
#10 Posted: 1/14/2022 4:25:17 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi ovlerlord.
Answer is YES
Yes, it is YES.
This version of your application doesn't need maple for get the simplified lagrange polynom.
lagrange.sm (22 KiB) downloaded 90 time(s).
overlord 1/14/2022 5:46:00 PM
#11 Posted: 1/17/2022 12:15:21 AM
rex
rex
Hi Jean,
Please, attach your raw data set., i.e: not freaked by else.
Two more examples attached.
Genfit Frechet DIFFICULT.sm (128 KiB) downloaded 66 time(s).
Genfit Kirby_2 [Reduced] Copy.sm (81 KiB) downloaded 68 time(s).
A fitting session is mostly governed by the model and techniques.
In short: sky is the limit. Some data set can only be fitted by hand.
Plenty are willing in Smath Community.
Take care ... Jean
Hi Jean,
see the stress-strain data, I would say I am really happy about this forum. I got a lot of fit function information from here! Thanks all!
#12 Posted: 1/17/2022 4:55:01 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Three fitting models for your data.
fit_stress_strain.sm (523 KiB) downloaded 98 time(s).
fit_stress_strain.pdf (635 KiB) downloaded 106 time(s).
Fridel Selitsky 1/17/2022 5:00:00 AM
#13 Posted: 1/17/2022 5:58:00 AM
rex
rex
Wow, it's amazing!
Thanks Alvaro!
#14 Posted: 1/26/2022 6:21:34 PM
983 likes in 6866 posts.
Hi Jean,
I tried the .sm file, but it doesn't work well.
You have detected a bug wrt your SS version, maybe earlier ones ?
Silent Smath Community ?
If you open the governing Conjugate Gradient ... it could be
the symbolic module has not been saved Symbolic, a common bug reported.
By same token, I will delete all previous attachments.
Please, don't hesitate ... Take care ... Jean.
I guess your original raw data is the one from Alvaro ?
  • New Posts New Posts
  • No New Posts No New Posts
