Slope Stability Analysis
Slope Stability Analysis - A basic approach to find cutting points of strips with profile and slip circle - Messages
#1 Posted: 9/16/2023 5:01:44 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Ref: Example 12.2 (Page 296) - Soil Mechanics : Principles and Practice by G.E. Barnes.
The attached SM file demonstrates how to find cutting points of strips with the slope profile and slip circle.
(for an assumed strip width of 1m. which can be changed if necessary).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.pdf (238 KiB) downloaded 113 time(s).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.sm (320 KiB) downloaded 95 time(s).
sergio 9/16/2023 6:05:00 AM, Dionysios J. Pantazis 10/31/2023 2:31:00 AM
#2 Posted: 9/16/2023 7:51:13 AM
NDTM Amarasekera
NDTM Amarasekera
A small text correction to my post #1.
Sorry for inconvenience please.
Point A and Toe are also same.
Alvaro Diaz Falconi 9/17/2023 5:18:00 PM, Oscar Campo 9/16/2023 10:55:00 AM
#3 Posted: 9/16/2023 1:06:16 PM
NDTM Amarasekera
NDTM Amarasekera
Second correction, as the variable Hvc is no longer used in the entire program. Please delete the entire line as indicated.
Extremely sorry.
#4 Posted: 9/20/2023 1:55:02 AM
NDTM Amarasekera
NDTM Amarasekera
The complete solution to Slope Stability Analysis of above example.
Analysis is carried out in 2 parts.
1. With one assumed Center of a slip circle to explain steps involved and resulting cordinates of strips etc., and checked with ACAD drawing.
2. Program to find the minimum factor of safety using multiple arrays of centers.
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.pdf (334 KiB) downloaded 84 time(s).
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.sm (522 KiB) downloaded 73 time(s).
Alvaro Diaz Falconi 9/20/2023 1:14:00 PM, Oscar Campo 9/20/2023 6:39:00 AM, ioan92 9/20/2023 8:01:00 AM
#5 Posted: 9/21/2023 7:45:50 AM
NDTM Amarasekera
NDTM Amarasekera
Please make the correction as shown ( replace A with -A in page 3).
Even without this correction, the program will run in most cases, but will give
wrong values for AA for some center cordinates.
This correction is an improvement.
Sorry for the inconvenience.
Oscar Campo 9/21/2023 1:47:00 PM
#6 Posted: 10/28/2023 9:32:18 PM
NDTM Amarasekera
NDTM Amarasekera
An improved method to my post #5.
I get Wrong Values OR Errors when using the "Findroot()" function for some center cordinates.
This new method mainly uses "root()" function, with few supporting programs.
Slip Circle Intersection Points - TO FORUM.pdf (392 KiB) downloaded 102 time(s).
Slip Circle Intersection Points - TO FORUM.sm (247 KiB) downloaded 86 time(s).
Oscar Campo 10/28/2023 10:03:00 PM, Alvaro Diaz Falconi 10/29/2023 3:11:00 AM, sergio 10/30/2023 3:59:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
