Problems with plotting
Problems with plotting - jaid - Messages
#1 Posted: 2/8/2013 9:05:01 PM
jaid
jaid
0 likes in 2 posts.
First off I'm sorry to post this, I've seen several different posts and topics about issues with plotting and I have read through the different pdfs and tutorials for SMath, but I still can't figure out how to use 2D plots. I've even gone as far as trying to copy several of the examples directly into SMath to see if it would make a difference, but I still can't get the plots to show up properly.
These are two of the examples I've tried copying but for some reason they aren't plotting correctly or even plotting at all. Is there a plugin I'm missing or is it just human error???
#2 Posted: 2/8/2013 10:46:16 PM
kilele
kilele
133 likes in 397 posts.
hi
did you type the array this way? r[i
btw here you can read about how to attach files and pictures on the forum.
graph1.sm (4 KiB) downloaded 59 time(s).
Davide Carpi 2/9/2013 6:30:00 AM
#3 Posted: 2/8/2013 10:59:55 PM
jaid
jaid
0 likes in 2 posts.
hi
No, o_o I thought the i's were added as subscripts using r.i but using [ instead of . looks like it fixed the problem.
It also looks like it solved the same issue with another example that was causing trouble.
Thank you for the help and for the link!!
  • New Posts New Posts
  • No New Posts No New Posts
