Error by ODEs solution
Error by ODEs solution - Help please - Messages
#1 Posted: 12/14/2023 1:35:18 AM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
Here OK Rocket-1.sm (16 KiB) downloaded 52 time(s).
Here not OK Rocket-2.sm (688 KiB) downloaded 46 time(s).
About the problem Study-24-How-calculate-Rocket.doc (1 MiB) downloaded 65 time(s).
from the book
https://www.routledge.com/25-Problems-for-STEM-Education/Ochkov/p/book/9780367345259
#2 Posted: 12/14/2023 9:58:26 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi Valery. Just use cases() instead if() clauses.
Rocket-2.sm (688 KiB) downloaded 47 time(s).
But Newton's second law is not F=ma which is an expression valid only for systems where m is constant. The general expression given by Newton is F=d(mv)/dt or F=dp/dt with p=mv the linear momentum.
Valery Ochkov 12/14/2023 2:13:00 PM
#3 Posted: 12/14/2023 2:30:08 PM
Valery Ochkov
Valery Ochkov
Thanks, Alvaro!
One questions.
How can we solve this problem with ODE as F=dp/dt, not F=m dv/dt?
Will we get others (numerical) answer?
Rocket-2-otherwise.sm (690 KiB) downloaded 54 time(s).
#4 Posted: 12/14/2023 6:32:10 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
The speed of the rocket cannot be independent of the speed at which the propellant exits. Entering that information gives me this solution
Rocket-1.sm (20 KiB) downloaded 50 time(s).
Another way of looking at it, using the equation F = d(mv)/dt, we must take into account that in a rocket the reaction force is not applied to the same body as the action force, as the 3rd Law says, and therefore the temporal derivative of the product mv must be done by changing the reference frame, which is why it is F = m dv/dt + u dm/dt, where v is the speed of the rocket with respect to the inertial reference system attached to the earth, but u is the speed of the propellant with respect to the non-inertial reference system attached to the rocket
#5 Posted: 12/14/2023 6:35:31 PM
Valery Ochkov
Valery Ochkov
New question
Rocket-1.sm (734 KiB) downloaded 43 time(s).
#6 Posted: 12/15/2023 1:16:32 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
New question...
Hi Valery. You can't take the temporal derivative directly. Please see my previous answer explaining why I think that.
#7 Posted: 12/15/2023 2:39:15 AM
Valery Ochkov
Valery Ochkov
New question...
#8 Posted: 12/15/2023 3:25:33 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Valery. You're right encircling u. Its correct value is u = F/μ. Thus, the force over the rocket is F = - mg - u*dm/dt
Rocket-1.sm (23 KiB) downloaded 48 time(s).
#9 Posted: 12/15/2023 4:04:15 AM
Valery Ochkov
Valery Ochkov
Thanks, Alvaro.
And what about the 2-stage rocket?
Our first try
Rocket-2.sm (690 KiB) downloaded 53 time(s).
#10 Posted: 12/15/2023 4:30:05 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Our first try
Hi. Your original solution for rocket-1 is ok, and that implies that the movie's solution is also ok.
I was only pointing out the way to deduce it. Writing the relationship for several stages would imply asking for derivatives for functions with cases(), which cannot be done, because although functions can be integrated with cases() or using inside the Mathcad block, they definitely cannot be derived.
So I guess the best solution is the one you gave at the beginning, simply replacing the if() with cases(). The deduction based on physical principles has already been done for one stage. Now it remains to apply the simplified result for several, which is exactly what the rocket-2 case does.
#11 Posted: 12/15/2023 5:00:55 AM
Valery Ochkov
Valery Ochkov
I think it is easier to solve two equations - for two stages, and then for one (last) stage of the rocket.
#12 Posted: 12/15/2023 6:58:19 AM
1222 likes in 2150 posts.
Analytical reference solution for h(t) (from a mechanics textbook) and with a single second order DE. in() would be even better without braces (operator form)
Rakete.sm (21 KiB) downloaded 55 time(s).
Rakete2.sm (21 KiB) downloaded 62 time(s).
#13 Posted: 12/16/2023 3:47:47 PM
Valery Ochkov
Valery Ochkov
I would like to publish an article about Rockets in the Journal "Physic in school".
Martin, Rasonar!
Would you like to be coauthors?
See please attach
Polet na Lunu.docx (585 KiB) downloaded 51 time(s).
Rakete-1.sm (16 KiB) downloaded 55 time(s).
Rakete-2.sm (17 KiB) downloaded 55 time(s).
Alvaro Diaz Falconi 12/17/2023 2:04:00 AM
#14 Posted: 12/17/2023 2:10:50 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Martin, Rasonar!
See please attach
Hi Valery. Sure. It will be a great experience.
#15 Posted: 12/17/2023 5:05:30 AM
983 likes in 6866 posts.
The book about Holistic is the rocket model ... works fine in Smath 30405.
Once data will be collected clean, it may be interesting to collect as a function.
A good candidate may be Thiele.
The rocket system does not follow a single DE law, Like ISA.
Thiele fits ISA form - 1km ... 100 km
Jean.
#16 Posted: 12/17/2023 5:49:57 AM
Martin, Rasonar!
See please attach
Polet na Lunu.docx (510 KiB) downloaded 44 time(s).
Of course. If I remember correctly, some time there were examples for three-body problems earth-moon-spacecraft. Can't find it just now but that could make another co-author.
Edit: https://en.smath.com/forum/yaf_postsm76986_Mathcad-Toolbox.aspx#post76986
#17 Posted: 12/17/2023 3:12:04 PM
Valery Ochkov
Valery Ochkov
See see please solutions from Slava
three bodies problem
#18 Posted: 12/17/2023 9:42:27 PM
I tried Cholesky ... Quite good.
For this 6 points Rocket from the book, Holistic works fine.
Unfortunately, we don't have an exportable formula.
Re-Conciliate the project ... Thiele
#19 Posted: 12/17/2023 10:33:09 PM
Valery Ochkov
Valery Ochkov
Thanks, Alvaro!
My email OchkovVF@mpei.ru
#20 Posted: 12/18/2023 7:35:01 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
3 stages variation.
Checking with Tsiolkovsky rocket equation in a gravitational field with several stages
Rakete-3.sm (46 KiB) downloaded 54 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
