Analog Clock
Analog Clock - A simple animation - Messages
#1 Posted: 7/9/2013 10:24:35 AM
1417 likes in 2873 posts.
A simple animation
Best Regards,
Davide
AnalogClock_viewer.7z (355 KiB) downloaded 189 time(s).
4 users liked this post
ioan92 7/9/2013 11:21:00 AM, Вячеслав Мезенцев 7/11/2013 1:12:00 PM, Andrey Ivashov 7/10/2013 8:27:00 AM, Fridel Selitsky 7/9/2013 2:27:00 PM
#2 Posted: 7/9/2013 4:51:49 PM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Beautiful animation: To reduce the computation time can be operators "for", which do not depend on time, move out of the function cloc (s).
Best Regards,Ber7.
AnalogClock1.sm (22 KiB) downloaded 165 time(s).
Davide Carpi 7/9/2013 5:15:00 PM, Andrey Ivashov 7/10/2013 8:27:00 AM
#3 Posted: 7/9/2013 5:20:04 PM
Thank you ber,
this make the script faster and easier to read
Best regards,
Davide
P.S. worksheet updated
#4 Posted: 7/11/2013 5:37:01 AM
Fridel Selitsky
Fridel Selitsky
Davide,if your program to change the settings a bit, we get
"real" analog clock (all the arrows are moving continuously).
Best Regards,
Ber7
AnalogClock2.sm (21 KiB) downloaded 207 time(s).
Вячеслав Мезенцев 7/11/2013 1:12:00 PM, Davide Carpi 7/11/2013 8:45:00 AM
#5 Posted: 7/11/2013 8:49:18 AM
I see, wonderful
#6 Posted: 7/16/2019 12:08:53 AM
983 likes in 6866 posts.
Best Regards,Ber7.
Glorious old vintage, before I joined Smath.
More elegant needles in there ... needs be animated
attach]31143[/attach]
#7 Posted: 7/18/2019 2:24:18 PM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Cheers to all!
This is my 5 cents to this thread. I only took some pieces of code from here and there, a little bit of make up, and.. voilá: my version of analog clock that works on "real" time
Updated 19jul2019 (Special thanks to [USERLINK]Razonar[/USERLINK]):
Annoying "purple line" eliminated. Path for sound files fixed. More realistic movement of hands clock.
MyClock2.sm (38 KiB) downloaded 83 time(s).
click_low.wav (171 KiB) downloaded 81 time(s).
alarm.wav (891 KiB) downloaded 75 time(s).
frapuano 7/18/2019 2:53:00 PM, Alvaro Diaz Falconi 7/19/2019 2:04:00 AM
#8 Posted: 7/19/2019 2:25:06 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hola Oscar. Very nice effects.
You can improve it multiply Play() by 1000 or something else but big. This avoid the horizontal purple line in the clock.
Also you define the location of the files as "D:\sound.wav". Using 1000*Play("sound.wav" ) searches sound in the same directory of the SMath file.
Finally notice that your blue hours hand jumps between hours, but not follow the actual movement of an hours hand clock. You need to take 1/2-1/6*el(NOW,1)-el(NOW,2)/600 as the arguments for sin, cos functions for place it between exact hours considering the minutes too.
frapuano 7/19/2019 5:23:00 AM, Oscar Campo 7/19/2019 5:39:00 PM
#9 Posted: 7/19/2019 6:15:08 PM
Oscar Campo
Oscar Campo
Thanks for your suggestions Also I considering the seconds in the movement of the minutes hand for a more realistic appearance.
I've updated the file and I uploaded the new one, you can check it here.
  • New Posts New Posts
  • No New Posts No New Posts
