1 Pages (5 items)
[SS-4609] No XML start tag open - Missing XML start tag - Messages
#1 Posted: 10/3/2019 12:43:28 PM
Can anyone help recover this file? It says that there is no XML start tag open. See attached
Thanks in advance!
New Beam Design.sm (191 KiB) downloaded 89 time(s).
Thanks in advance!
#2 Posted: 10/3/2019 4:02:08 PM
WroteCan anyone help recover this file? It says that there is no XML start tag open. See attached
Thanks in advance!
Fixed.
New_Beam_Design_fixed_alyles.sm (200 KiB) downloaded 98 time(s).
For anyone curious. I ended up fixing an empty tag for this particular area title to have an explicit start and end tag. I don't know enough about the SMath parser to know why this is a problem. I didn't try deleting it.
Problem:
Solution
#3 Posted: 10/3/2019 4:36:23 PM
Thanks Alyles!
#4 Posted: 5/20/2020 12:25:47 PM
#5 Posted: 5/20/2020 3:36:49 PM
WroteI had the same problem, how did you find the error? There are so much lines y don't know how to find the error
If you have an editor that supports syntax highlighting for xml is easier, usually you can collapse blocks of code and you can spot where something is wrong. You can try to check yourself using programs such as notepad++ or visual studio code.
1 Pages (5 items)
New Posts
No New Posts
