1 Pages (7 items)
data output - Messages
#1 Posted: 8/2/2022 3:17:42 PM
#2 Posted: 8/17/2022 2:07:27 PM
I think I understood what you are trying to do. Take a look at this example.
data_output.sm (9 KiB) downloaded 65 time(s).
There is also a couple way to handle the input depending on if you work with SMath solver worksheets or with SMath Viewer EXE files.
#3 Posted: 8/18/2022 4:13:30 PM
WroteI think I understood what you are trying to do. Take a look at this example.
Thanks, this is a good way for me. (I came up with method: inserted it instead of empty elements 0, and then the cycle if/else a or b.)
I'm trying to work with SMath Viewer EXE files.
Such a question appeared: How to replace b2 and b3 on 0, if selected "standard"?
#4 Posted: 8/18/2022 6:39:51 PM
As far as I understand there is no way to modify the values in the data input fields. Only by manually changing them yourself.
#5 Posted: 8/18/2022 8:38:06 PM
We are talking about SMath Viewer here Jean. This topic is out of your world.
#6 Posted: 8/19/2022 4:11:35 PM
WroteAs far as I understand there is no way to modify the values in the data input fields. Only by manually changing them yourself.
thank for the answer.
Another question: How can I display data d1 and d2 if the matrices are of different sizes (for example, there will be a different number of columns or data will be in different columns)?
#7 Posted: 8/20/2022 4:15:57 PM
That can be a bit tricky because SMath Viewer doesn’t display matrices at all. You need to use a table extension or display the values in a plot. The table region is nice, but has its limitations. It doesn’t handle variable inputs that well within the Viewer.
1 Pages (7 items)
New Posts
No New Posts
