Roots - intersection points
Roots - intersection points - Trouble with finding intersection points of a line and a parabola using "roots" command. - Messages
#1 Posted: 4/14/2023 4:43:40 PM
SERGIO MARQUES DE SOUZA
0 likes in 3 posts.
Good afternoon everyone.
I'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
Roots.sm (8 KiB) downloaded 46 time(s).
Click to enlarge
#2 Posted: 4/14/2023 5:35:21 PM
983 likes in 6866 posts.
As doctored ... Jean
Roots Doctored.sm (9 KiB) downloaded 54 time(s).
#3 Posted: 4/14/2023 6:41:21 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi Sergio. There are a 3 argument version of roots, where the third is a guess value for the root.
Roots.sm (9 KiB) downloaded 66 time(s).
#4 Posted: 4/15/2023 8:54:21 AM
'roots' is essentially based on differentiable function.
Often, in Engineering works you don't have differentiable functions,
Gamma(x), spline fit ... etc.
In those cases, use the X(Φ,a,b,ε) utility.
roots Gamma(x).sm (18 KiB) downloaded 51 time(s).
#5 Posted: 4/15/2023 7:31:34 PM
554 likes in 1333 posts.
Here your solution solved with maple plugin.
No need to enter guess points for this.
Maxima can solve it too, similarly.
PS: MapleCorrect() function can be found here.
Assign() function can be used instead of str2num() + num2str() + strrep().
#6 Posted: 4/15/2023 8:44:04 PM
1222 likes in 2150 posts.
My personal favourite way to handle solver results is Davide's at() substitution function.
#7 Posted: 4/16/2023 2:49:20 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This is another way.
Roots.sm (16 KiB) downloaded 65 time(s).
#8 Posted: 4/16/2023 9:11:08 AM
Many Smath built-in functions are not differentiable.
diff(▄ ▄) not defined ... Airy example attached.
roots Airy.sm (11 KiB) downloaded 46 time(s).
#9 Posted: 4/16/2023 11:22:35 AM
What the heck? Can we use maple keywords if they are written as `function`?
This is so mind-blowing, thanks Razonar.
Alvaro Diaz Falconi 4/17/2023 5:27:00 PM
#10 Posted: 4/16/2023 6:34:02 PM
#11 Posted: 4/17/2023 1:44:30 AM
I found a Windows laptop.
And tried Maxima plugin Solve().
It can solve easily.
  • New Posts New Posts
  • No New Posts No New Posts
