Beta: SMath Studio 0.99.7251 (08 November 2019)
Beta: SMath Studio 0.99.7251 (08 November 2019) - Messages
#1 Posted: 11/8/2019 12:19:40 PM
2270 likes in 3734 posts.
Changes introduced in current build 0.99.7251
Miscellaneous
  • Calculation error introduced in previous beta version fixed in symbolic engine;
  • Calculation performance improved;
  • Refactoring.
Download
SMathStudioDesktop.0_99_7251.Mono.tar.gz (1 MiB) downloaded 3255 time(s).
SMathStudioDesktop.0_99_7251.Setup.msi (2 MiB) downloaded 17931 time(s).
sergio 11/8/2019 1:19:00 PM, NDTM Amarasekera 11/9/2019 3:44:00 AM, Serg 11/13/2019 3:12:00 AM
#2 Posted: 11/15/2019 11:58:51 AM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Blackout issue
I have the same issue (0.99.7251.32800) with the acoustic file on https://en.smath.com/forum/yaf_postsm59725_Summation-of-log-functions.aspx#post59725
#3 Posted: 11/15/2019 12:12:56 PM
983 likes in 6866 posts.
As soon as it was noticed, I gave the cure.
Why not suite the original thread ?
#4 Posted: 11/21/2019 1:19:08 PM
Ruben Sidranski
Ruben Sidranski
Why not suite the original thread?
Because it's still a bug that popped up on some of my other sheets. I also posted in the other thread
#5 Posted: 11/21/2019 2:00:02 PM
Because it's still a bug that popped up on some of my other sheets.I also posted in the other thread
As long as you can doctor in two clicks.
#6 Posted: 11/21/2019 6:10:59 PM
Ruben Sidranski
Ruben Sidranski
Andrey,
Bug alert. I was updating a snippet in this version and it lost ALL of the information. I don't know if the rest of the data is still in this file
RS_User Defined Units.smz (4 KiB) downloaded 72 time(s).
This snippet had an issue in 99.7030 too (Portable)!
Could it be the SMZ file format? I saved a version as SM and that appears to be OK. However, another file, not used as a snippet, saved OK in both formats. The regions or areas?
Alvaro Diaz Falconi 11/22/2019 12:42:00 AM
#7 Posted: 11/21/2019 8:45:19 PM
Bug alert.I was updating a snippet in this version and it lost ALL of the information.I don't know if the rest of the data is still in this file
Use your backup, re-save
#8 Posted: 11/22/2019 12:44:07 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1674 posts.
Andrey,
Bug alert. ...
Hi. I save as smz a file with an area, and have the same issue. appVersion = "0.99.7251.32800"
#9 Posted: 12/15/2019 7:20:14 AM
554 likes in 1333 posts.
The last two versions (7250-7251) are not working on fully updated Arch Linux with Mono.
7219 is working but it has two glitches which are lowercase greek character related.
#10 Posted: 1/2/2020 3:40:05 PM
1222 likes in 2150 posts.
The interactive "Getting started" guide has been updated to SMath version 7251. Most of the update work was spent on utilizing the new features of the text region
- Arial as default font (saves approx. 20-30% of space compared to Courier New)
- Usage of embedded math in text regions
The new version is marked as "beta". You need to install the latest beta version 7251 and some plug-ins.
4 users liked this post
sergio 1/2/2020 4:04:00 PM, NDTM Amarasekera 1/2/2020 11:30:00 PM, frapuano 1/3/2020 9:30:00 AM, Alvaro Diaz Falconi 1/3/2020 1:49:00 PM
#11 Posted: 1/3/2020 12:02:08 PM
Ruben Sidranski
Ruben Sidranski
Martin,
The NEW interactive guide is not showing up for me. On my end, it shows you posted this message 20 hrs ago. Did the updated file upload correctly?
Thank you for updating the documentation
#12 Posted: 1/3/2020 4:20:52 PM
Martin,
The new version has been downloaded several times, thus it should be accessible.
Make sure to
- search for it in Extension manager as Example (not as interactive book)
- allow for beta versions in the online gallery
If that doesn't work, you still can download the file from the extension summary page as linked in my previous post. Then open it in SMath Studio just as any other sm file.
#13 Posted: 1/13/2020 6:13:17 PM
Ryan Freund
Ryan Freund
19 likes in 339 posts.
Has anyone noticed that the "newer" versions does not underline the space between words?
Is this intended?
Is there a way for me to change this?
Thanks!
#14 Posted: 1/14/2020 7:52:20 AM
Isn't true that you can underline something existing: word, letter, symbol
Did you mean underscore between two words ?
Do you refer to text, formula ?
#15 Posted: 1/15/2020 4:24:16 AM
genf
genf
6 likes in 72 posts.
Доброго времени суток!
При наборе текста по умолчанию если нет пробелов, то этот текст является переменной, но как только появляется хотя бы 1 пробел эта переменная преобразуется в текст.
Если к этому тексту применять форматирование (например подчеркивание), то в версии 7030 пробелов не было, а в 7251 есть пробелы (разрывы) в подчеркивании:
Probely v podcherkivanii.sm (1 KiB) downloaded 55 time(s).
Спасибо!
Еще всплыл один вопрос: сейчас по умолчанию шрифт изменился на Arial.
Можно ли это умолчание поменять? Дело в том, что при редактировании старых расчетов, а именно - добавление новых областей, шрифт в них не меняется.
В итоге получается так:
Ryan Freund 1/15/2020 12:28:00 PM
#16 Posted: 1/15/2020 12:24:41 PM
Ryan Freund
Ryan Freund
Sorry for my delayed response. What genf shows is what I'm talking about.
I want all text and spaces between underlined like this
Not just the text like this
I beleive the first instance is fairly standard for most text editor applications.
Also if I change the text to Courier New it works as I expect. If it is Arial (or others) it does not.
Thanks again
#17 Posted: 1/15/2020 1:16:26 PM
Writer region does it piece wise or global.
Davide Carpi 1/16/2020 8:35:00 AM, Serg 1/17/2020 3:38:00 AM
#18 Posted: 1/15/2020 4:14:07 PM
Ryan Freund
Ryan Freund
@Jean - Good point. I suppose that is a 'workaround' for now.
#19 Posted: 1/17/2020 3:38:07 AM
genf
genf
Ну это как вариант, но в 7030 то все нормально было ведь.
Как оказалось это проблема в шрифте Arial, с другими такого нет (например Arial Narrow).
Как быть со шрифтом в заголовке области?
#20 Posted: 4/1/2020 7:58:28 AM
Mathys
Mathys
0 likes in 3 posts.
Hello dear Smath fans,
with v0.99.7251 I cannot open any longer the "Format..."
menu with the right mouse button on inserted x-y-Plots.
After clicking on it, Smath is freezed.
After minimizing Smath to the task bar with third party tools
and reopen this Smath process again from the task bar
I am able to edit the open document without issues.
But as soon as I try to use "Format..." again on any x-y-plot,
the freezing happens againg. So the usual format pop-up
window does not appear at all.
Is this the right forum group for this issue?
Or is it better to place it elsewhere? E. g.
"SMath Studio Forum » SMath Studio » Bugs & Problems"
Thanks and regards
P.S.:
After some testing with parallel installation of
  • stable version v0.99.7030 and
  • beta version v0.997251
and after deleting all plugins and reinstallation
of a couple of required plugins the problem of
missing "Format..." popup for x-y-plots disappeared.
Strange. ---> I will monitor and report any new findings.
  • New Posts New Posts
  • No New Posts No New Posts
