Run - Extends SMath Studio with the ability to run other worksheets in background - Messages
#1 Posted: 4/12/2016 2:46:51 PM
1417 likes in 2873 posts.
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
  • installation: SMath Studio: Tools > Plugins... > Online Gallery (be sure to have the "Exclude beta-versions" unchecked);
  • documentation: (beta) Run Example.7z (4 KiB) downloaded 244 time(s)..
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
5 users liked this post
sergio 4/12/2016 3:41:00 PM, ElSid 4/12/2016 4:35:00 PM, frapuano 4/12/2016 4:49:00 PM, Вячеслав Мезенцев 4/13/2016 1:14:00 AM, Kemili 4/13/2016 1:38:00 PM
#2 Posted: 4/12/2016 4:09:25 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Will this allow us to transfer data? SWEET!
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile,
wfile, importData, exportData, ...).
#3 Posted: 4/13/2016 2:21:48 PM
Is more targeted to process data "remotely"; data transfer is driven by existing functions (also include());
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile, wfile, importData, exportData, ...).
I think the only other way, in the scenario drawn in the example of the first post, would be to transfer data via functions, that is not a feasible way as for now.
Also, I have to improve the log system to better recognize if there are errors in the target worksheets.
#4 Posted: 4/15/2016 5:12:30 PM
Ruben Sidranski
Ruben Sidranski
How is this different than "Include" plug in by Uni?
#5 Posted: 4/16/2016 12:39:42 PM
Mainly:
include() loads the SMath variables/functions from the target worksheet into the one in use, while in Run() each worksheet is indipendent;
include() can't run non-math regions (ComboBoxList, etc...) while Run() execute everything;
#6 Posted: 8/27/2016 2:28:06 AM
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
  • requirements: SMath Studio 0.98.5935 or later;
  • Problem in 98.6081?
    #7 Posted: 8/27/2016 8:48:06 AM
    983 likes in 6866 posts.
    Hello collab ndtma,
    Don't take my comment bad. Your snippets are always blurry [not comfortable].
    You can "PrintScreen" paste in Paint to select the portion. That results in
    huge BMP... then reduce to 256 via IrfanView: superfreeware of multiuse ...
    mostly: sharpen image, superbe Lanczos zoon [square/rectangular] gray/color
    images ++++ .
    I use this technique as well as capture a selected region from WinGrab
    [freeware]. Wingrag has more options to reduce 256 colors, in many difficult
    cases of better quality than IrfanView, though is does not apply to Smath snippets.
    Cheers, Jean
    #8 Posted: 8/27/2016 10:10:59 AM
    NDTM Amarasekera
    NDTM Amarasekera
    Hello Jean,
    Thanks for your valuable suggestions.
    #9 Posted: 8/27/2016 10:29:53 AM
    Problem in 98.6081?
    Hello ndtma,
    yes, seems there are isSies with the process handle. I'm looking to find the cause and if I can solve it
    #10 Posted: 8/29/2016 1:05:21 PM
    Issue found.
    edit: fixed in SS 0.98.6179
    #11 Posted: 11/1/2018 3:30:04 PM
    Kyle Sullivan
    Kyle Sullivan
    0 likes in 7 posts.
    Hi Davide, I created my own example with a 3x3 excel table and it takes about 6 seconds for the "Run" function to execute each row of test data during the for loop. The smath sheet it's running contains 2 variables multiplied together and output as a variable 'd'. Your entire example runs in 22 seconds, with definitely a bit more complexity, but not much. Any ideas here? I'd like to run 400 rows of data (load cases for different members) through a calc sheet and collect the results, just like you've done (except only one calc sheet, not 3 like you've done).
    thx!
    #12 Posted: 11/2/2018 7:24:46 AM
    Currently each Run function triggers a new instance of SMath Studio; this means that all the initialization process must be done every time, rising the execution time. What you can try is to change the logic to start a single run with multiple worksheets, and init/finalize each loop step in a dedicated file.
    new loopSheet.sm
    initCalc.sm
    handleCalcResults.sm
    Kyle Sullivan 11/2/2018 1:55:00 PM
    #13 Posted: 11/2/2018 2:32:57 PM
    Kyle Sullivan
    Kyle Sullivan
    0 likes in 7 posts.
    Thanks for the response Davide.
    So I went ahead and tried out your idea, it does solve the only 'running' once issue and finishes the script in 6 seconds no matter what.
    But now I have the issue where the Run(exec) command does not seem to be running all the scripts in the exec matrix, or somehow it's only saving the first 'calcResults' in 'allResults'. That said, I was successful in manually looping the 3 sheets, so I thin something is going on incorrectly in the run(exec) line.
    You can see what I did in the gifs below if you open them full size in a new tab..
    Thoughts?
    Calc completed successfully by manually looping the 3 sheets:
    Manual loop method works
    Calc running with loop sheet, only records first row result:
    #14 Posted: 11/2/2018 3:52:52 PM
    so I think something is going on incorrectly in the run(exec) line.
    That I don't understand the idea/purpose of run does not indicate it is useless.
    Do you mean run would calculate in a cash of some sort a selection of work sheets
    and then would show all calculated by clicking "Open file" ?
    #15 Posted: 11/2/2018 6:21:03 PM
    Alvaro Diaz Falconi
    Alvaro Diaz Falconi
    992 likes in 1674 posts.
    Thoughts?
    Hi K. Gif shows that you modify iniCalc.sm (disabling some calcs) but don't save it, so others SMath files read the original iniCalc.sm, not the modified. Is this the issue or I'm are not understanding something else?
    #16 Posted: 11/3/2018 12:05:52 AM
    Kyle Sullivan
    Kyle Sullivan
    0 likes in 7 posts.
    I reran it after saving everything and the same thing happened..here's a non-gif image and the files. I guess Davide's example ran fine so I should be able to figure this out haha. I'm currently troubleshooting so stay posted
    testCalc.sm (3 KiB) downloaded 86 time(s).
    handleCalcResults.sm (5 KiB) downloaded 79 time(s).
    initCalc.sm (9 KiB) downloaded 81 time(s).
    input.xlsx (8 KiB) downloaded 74 time(s).
    loopSheet.sm (10 KiB) downloaded 77 time(s).
    This gave me what I want..
    Run(exec)
    Run(exec)
    Run(exec)
    I quit, there's something with run() only running files if they have a different name, or the Run(exec) is called again (like above). I created a new, simpler example.. Below shows that if exec is defined with 3 separate but identical calc.sm files (calc1.sm, calc2.sm, etc) then run(exec) will run all 3 files and the allResults var is fully populated. If I define exec as a vector with all the same calc.sm files then it won't work and allResults will just end up with the first result.
    calcSheet.sm (5 KiB) downloaded 78 time(s).
    loopSheet.sm (5 KiB) downloaded 73 time(s).
    #17 Posted: 11/3/2018 3:46:07 PM
    You are right, I have to investigate it.
    #18 Posted: 11/3/2018 8:54:20 PM
    Document calcSheet calculates nothing [no maths/formula(s)/result(s)]
    Certainly no gadget will retrieve something from nothing, is it ?
    If calcSheet calculates something, save to file and retrieve from
    any other Smath work sheet. On the other hand, you may save formula(s)
    in calcsheet and retrieve from any other Smath work sheet then modify
    the formula(s) in the working document ... per say change parameters.
    You say nothing about what you have in mind.
    #19 Posted: 11/3/2018 10:54:49 PM
    Kyle Sullivan
    Kyle Sullivan
    0 likes in 7 posts.
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data my previous example actually took one of the values in the 'current row' and multiplied it by 3. I just wanted to make the example here as simple as possible so we could hone in on the problem.
    #20 Posted: 11/4/2018 12:38:23 PM
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data my previous example actually took one of the values in the 'current row' and multiplied it by 3.I just wanted to make the example here as simple as possible so we could hone in on the problem.
    Simply attach the basic project and describe the next part of the project.
    As you explain, it looks weird from maybe baby simple.
    • New Posts New Posts
    • No New Posts No New Posts
