1 Pages (8 items)
lookup fuction - Messages
#1 Posted: 3/6/2023 5:02:40 AM
I would like to have a function like lookup (vlookup, hlookup) in smath.
thank you.
thank you.
João Felipe Seráfico Melo 3/6/2023 10:09:00 AM
#2 Posted: 3/6/2023 5:45:04 AM
findrows function within Special Functions plugin is what you're looking for, soomoon
#3 Posted: 3/6/2023 8:36:22 AM
WroteI would like to have a function like lookup (vlookup, hlookup) in smath.
Find Index Key Code is lot more powerful.
Assume your Customer wants more information from his bar diameter
you can give all pertaining informations ...
Add price column, material, delivery ... etc.
bar size Findndex KeyCode.sm (10 KiB) downloaded 88 time(s).
#4 Posted: 3/6/2023 9:14:07 AM
João Felipe Seráfico Melo 3/6/2023 10:05:00 AM
#5 Posted: 3/6/2023 10:05:04 AM
Jean, your example shows EXACTLY what findrows does.
#6 Posted: 3/6/2023 5:23:05 PM
WroteJean, your example shows EXACTLY what findrows does
Yes for that simple application.
FindIdx(V,x,col) gives me more for advanced Engineering works
Thanks for the observation.
#7 Posted: 3/6/2023 11:46:16 PM
https://en.smath.com/forum/yaf_postst673_lookup.aspx
Check thread above. You may find it useful.
You can look forum for your questions by searching too.
Searching may result with a ready answer to a question.
#8 Posted: 3/7/2023 12:30:02 PM
findrows() function revisited.
As a part of a project undertaken to study flows of some perennial streams in Sri Lanka,
a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was
prepared relating water levels to flows. This process took a few years so that the
data would almost cover reasonable range of depths for practical reasons, excluding severe floods.
During this period, an electronic device was also constructed to measure water levels (WL) and
transmit as digital signals to control station in Colombo.
However, the numerical values of transmitted WL had more than 6 decimals,
whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values
had to be refined to 2 decimals for use with RT values.
Earlier a vlookup function which was posted in the forum was used, but it took a long time to process
But when the findrows function was available, data processing was dramatically fast.
Both Excel and SM files must be in the same folder.
Cheers
1.July WL&RT.xlsx (29 KiB) downloaded 52 time(s).
Find_Flows-R1.sm (26 KiB) downloaded 62 time(s).
Find_Flows-R1.pdf (234 KiB) downloaded 79 time(s).
Cheers
Mark R Harris 3/8/2023 4:34:00 PM
1 Pages (8 items)
New Posts
No New Posts
