[SS-13] Matrix Insert Row or Column
[SS-13] Matrix Insert Row or Column - Some data sets that were transcribed are missing insormation - Messages
#1 Posted: 4/12/2018 2:10:56 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 463 posts.
Adding a row or column in Mathcad, mid Matrix, was simple. In SMath, I cannot copy portions of the matrix to move the information (all or nothing) as I've tri. Am I missing anything?
Matrix -Insert Row or Column.sm (5 KiB) downloaded 97 time(s).
#2 Posted: 4/12/2018 2:19:30 PM
1417 likes in 2873 posts.
Cutrrently not possible: [SS-13]
#3 Posted: 4/12/2018 2:23:48 PM
Ruben Sidranski
Ruben Sidranski
Thank you Just added a vote to this item
#4 Posted: 4/12/2018 3:42:29 PM
983 likes in 6866 posts.
Easy/simple ... it's ADD not INSERT
Matrix -Insert Row or Column.sm (12 KiB) downloaded 133 time(s).
#5 Posted: 4/12/2018 8:35:51 PM
In SMath, I cannot copy portions of the matrix to move the information (all or nothing) ...
Simply => submatrix !
#6 Posted: 4/12/2018 8:37:35 PM
simply submatrix !
#7 Posted: 4/13/2018 3:26:21 AM
Martin_B
Martin_B
21 likes in 84 posts.
You can use this tool. It also allows conversion between Excel and Smath.
Smath Tools:
https://smath.info/wiki/Tools.ashx
#8 Posted: 4/13/2018 9:04:16 AM
Dead like stone, better use Smath tool ! page 14
Utilities Matrix Treasury_0 Copy.sm (496 KiB) downloaded 117 time(s).
#9 Posted: 4/16/2018 5:24:55 PM
Ruben Sidranski
Ruben Sidranski
Jean,
Sometimes your convoluted solutions really do inspire ... when I understand them
Here is a work around that works for me. I did NOT try it as an insert to column or row index 1 as I assume these exist. If those are needed, I guess we use augment. At the end of a matrix, we can just pull the handle. RS_Insert cols_rows to Matrices.smz (6 KiB) downloaded 100 time(s).
Thank you
#10 Posted: 4/16/2018 9:08:50 PM
Pad(M,nc,nr) ... padding a matrix has the meaning centered [nc,nr] insertion,
reserved for Fourier 'ifft'... why did you remove it.
For common work, rater use InsertCol/InsertRow.
RS_Insert cols_rows to Matrices(1).sm (47 KiB) downloaded 110 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
