AlgLib 3.1x - AlgLib Plugin (based on ALGLIB 3.1x) - Messages
#41 Posted: 12/24/2018 7:47:08 AM
Updated.
[albumimg]1560[/albumimg] [albumimg]1561[/albumimg] [albumimg]1562[/albumimg] [albumimg]1563[/albumimg]
alglib.ode.kinetic1.sm (7 KiB) downloaded 146 time(s).
alglib.ode.kinetic2.sm (10 KiB) downloaded 126 time(s).
alglib.ode.kinetic3.sm (10 KiB) downloaded 131 time(s).
alglib.ode.test1.sm (10 KiB) downloaded 143 time(s).
alglib.ode.test2.sm (10 KiB) downloaded 125 time(s).
alglib.ode.Amplitude detector.sm (19 KiB) downloaded 135 time(s).
alglib.ode.kinetic1.pdf (75 KiB) downloaded 134 time(s).
alglib.ode.kinetic2.pdf (89 KiB) downloaded 115 time(s).
alglib.ode.kinetic3.pdf (83 KiB) downloaded 123 time(s).
alglib.ode.test1.pdf (85 KiB) downloaded 114 time(s).
alglib.ode.test2.pdf (89 KiB) downloaded 119 time(s).
alglib.ode.Amplitude detector.pdf (147 KiB) downloaded 125 time(s).
5 users liked this post
bdrunagle 12/24/2018 8:15:00 AM, NDTM Amarasekera 12/24/2018 9:44:00 AM, sergio 12/24/2018 11:04:00 AM, frapuano 12/24/2018 2:22:00 PM, Radovan Omorjan 12/24/2018 2:52:00 PM
#42 Posted: 12/28/2018 2:02:54 PM
sergio 12/28/2018 4:14:00 PM, frapuano 12/28/2018 7:22:00 PM, NDTM Amarasekera 12/28/2018 10:53:00 PM
#43 Posted: 1/19/2019 4:31:14 PM
Updated. al_nleqsolve(2), al_nleqsolve(3), al_nleqsolve(4) added.
File not found. File not found. File not found.
#44 Posted: 1/27/2019 5:23:49 AM
With numeric optimization (for all functions) it works much faster.
Fourier series coefficients.sm (17 KiB) downloaded 120 time(s).
Fourier series coefficients.pdf (138 KiB) downloaded 113 time(s).
4 users liked this post
Radovan Omorjan 1/27/2019 8:19:00 AM, Davide Carpi 1/27/2019 7:53:00 AM, frapuano 1/27/2019 8:21:00 AM, NDTM Amarasekera 1/27/2019 9:47:00 AM
#45 Posted: 1/27/2019 10:59:21 AM
Example 2.
Fourier series coefficients.sm (28 KiB) downloaded 171 time(s).
Fourier series coefficients.pdf (170 KiB) downloaded 146 time(s).
sergio 1/27/2019 1:29:00 PM
#46 Posted: 1/27/2019 12:48:06 PM
Otherwise w/o Algib and more Engineering applications
Fourier Budapest39 Smoothing.sm (47 KiB) downloaded 116 time(s).
#47 Posted: 1/27/2019 1:06:32 PM
Fourier-Fejer-Lanczos interesting too.
IrfanView "ResizeResample" zoom up/down in two options
Fourier or Lanczos the best.
Fourier Fejer Lanczos.sm (9 KiB) downloaded 114 time(s).
#48 Posted: 2/18/2019 5:42:17 AM
Parameterization of implicit functions with al_nleqsolve
Parametrisation.sm (29 KiB) downloaded 121 time(s).
NDTM Amarasekera 2/18/2019 11:46:00 AM, frapuano 2/18/2019 9:08:00 AM, Alvaro Diaz Falconi 2/18/2019 2:00:00 PM, Вячеслав Мезенцев 2/18/2019 5:50:00 PM
#49 Posted: 2/18/2019 1:59:33 PM
Hi Ber. Nice technique, easy to implement. You can also make that as a function, and monocolor too.
Parametrisation.sm (25 KiB) downloaded 121 time(s).
Another option could be use y0 as vector, and solve for each element in y0, obtaining res, res1, ..., resn
Fridel Selitsky 2/18/2019 2:44:00 PM
#50 Posted: 2/18/2019 11:53:03 PM
1. SS 6179 does not complain
2. Takes ~ 1 hr to terminate the first function
3. NO plot result [NO complain but NO plot ?]
4. Would be interesting checking if the attached SS 6179
runs in your actual AlgLib 3.1x. If NOT => would be a dramatic bug.
It would indicate that all maths based al_nleqsolve would be scrap.
Contour SOLVE [Electron Solve algo Express].sm (20 KiB) downloaded 113 time(s).
#51 Posted: 11/22/2020 4:47:54 AM
#52 Posted: 2/22/2021 4:06:56 PM
sergio 11/17/2021 12:20:00 PM
#53 Posted: 11/17/2021 11:42:24 AM
Fridel Selitsky 11/17/2021 12:18:00 PM, sergio 11/17/2021 12:20:00 PM, Alvaro Diaz Falconi 11/17/2021 1:00:00 PM, NDTM Amarasekera 11/17/2021 4:44:00 PM
#54 Posted: 12/8/2021 2:43:14 AM
#56 Posted: 12/20/2021 4:18:35 PM
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
New Posts
No New Posts
