AlgLib 3.1x
AlgLib 3.1x - AlgLib Plugin (based on ALGLIB 3.1x) - Messages
#21 Posted: 7/17/2018 7:49:21 PM
1402 likes in 1708 posts.
Updated. al_nleqsolve() refactored. Try now.
You can also specify only names of the systems (f and j).
4 users liked this post
frapuano 7/18/2018 10:53:00 AM, Fridel Selitsky 7/18/2018 2:35:00 AM, Radovan Omorjan 7/18/2018 5:41:00 AM, Igor Skarine 7/18/2018 10:17:00 AM
#22 Posted: 7/18/2018 2:35:44 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
One example of V. Mezentsev (Uni)
Primer Uni.sm (13 KiB) downloaded 124 time(s).
Radovan Omorjan 7/18/2018 5:34:00 AM, frapuano 7/18/2018 10:53:00 AM
#23 Posted: 7/18/2018 5:40:48 AM
325 likes in 2052 posts.
Fortunately, I was wrong. We could use it with different number of equations and unknowns.
I just use the Ber7 example and change it with n as a global variable. No need for zeros as non-existing functions.
Primer%20Uni-mod.sm (13 KiB) downloaded 120 time(s).
#24 Posted: 7/18/2018 10:15:46 AM
Igor Skarine
Igor Skarine
14 likes in 97 posts.
Thanks a lot uni!
The issue listed in my post #18 has been resolved.
But for some reason simple Newton-Raphson with variable step usually
works better than al_nleqsolve.
#25 Posted: 7/18/2018 3:19:47 PM
983 likes in 6866 posts.
Can you demonstrate for this application ?
Solve al_nleqsolve-Electron.sm (18 KiB) downloaded 106 time(s).
#26 Posted: 7/21/2018 12:45:03 PM
Fridel Selitsky
Fridel Selitsky
We find several roots at once
Primer Uni3.sm (15 KiB) downloaded 116 time(s).
Primer Jean1.sm (14 KiB) downloaded 108 time(s).
frapuano 7/21/2018 1:44:00 PM
#27 Posted: 7/22/2018 3:50:27 AM
Fridel Selitsky
Fridel Selitsky
3d.sm (29 KiB) downloaded 111 time(s).
NDTM Amarasekera 7/22/2018 5:00:00 AM, frapuano 7/22/2018 5:30:00 AM
#28 Posted: 7/22/2018 11:29:32 PM
Thanks Ber7 for the 3D, nice.
#29 Posted: 7/24/2018 1:03:26 PM
Fridel Selitsky
Fridel Selitsky
Solution of an overdetermined system of equations. The problem is taken from here
https://en.smath.info/forum/yaf_postst12745_How-to-solve-it.aspx
Overdetermined.sm (15 KiB) downloaded 105 time(s).
Andrey Ivashov 7/26/2018 6:06:00 PM
#30 Posted: 7/30/2018 1:09:38 PM
Fridel Selitsky
Fridel Selitsky
The process of finding the roots
Primer Anim.sm (30 KiB) downloaded 103 time(s).
frapuano 7/30/2018 2:08:00 PM
#31 Posted: 8/22/2018 4:32:16 AM
Fridel Selitsky
Fridel Selitsky
The intersection points of two curves
Primer1b.sm (33 KiB) downloaded 109 time(s).
Primer1b.pdf (212 KiB) downloaded 97 time(s).
sergio 8/22/2018 5:52:00 AM, frapuano 8/22/2018 11:24:00 AM
#32 Posted: 8/22/2018 11:39:31 AM
Fridel Selitsky
Fridel Selitsky
Fixed. Now you can find all the intersection points.
Primer2.sm (36 KiB) downloaded 113 time(s).
Primer2.pdf (215 KiB) downloaded 103 time(s).
Davide Carpi 8/22/2018 11:41:00 AM, sergio 8/22/2018 1:01:00 PM
#33 Posted: 8/23/2018 5:11:57 AM
Fridel Selitsky
Fridel Selitsky
Primer3.sm (20 KiB) downloaded 109 time(s).
frapuano 8/23/2018 9:07:00 AM
#34 Posted: 8/23/2018 10:57:07 AM
... thanks Ber7
Contour SOLVE AstroidHyperbola.sm (20 KiB) downloaded 109 time(s).
#35 Posted: 8/25/2018 6:22:47 AM
Fridel Selitsky
Fridel Selitsky
Primer6.sm (18 KiB) downloaded 107 time(s).
#36 Posted: 10/6/2018 2:56:58 PM
Fridel Selitsky
Fridel Selitsky
Simple solutions to two problems
1.The construction of a sphere with respect to four given points
2.The construction of a circle with respect to three given points
To calculate the coordinates of the center and radius using the solver AlgLib
In the first problem, a system of four sphere equations for four given points is solved.
In the second - a system of three equations of a circle and the equation of a plane for three given points.
SphereAlglib.sm (64 KiB) downloaded 104 time(s).
NDTM Amarasekera 10/6/2018 10:52:00 PM
#37 Posted: 10/8/2018 3:23:09 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. The same, but without plugins.
SphereSMath.sm (75 KiB) downloaded 107 time(s).
PD: Do you know the angles for your rotation matrix gamma? I get this, but can't put the matrix elements in the correct order nor sign:
Actually, as I know, the minus in the last atan is a mistake, but at least give the same absolute values.
Fridel Selitsky 10/8/2018 3:35:00 AM, NDTM Amarasekera 10/8/2018 4:19:00 AM
#38 Posted: 10/9/2018 11:42:42 AM
Fridel Selitsky
Fridel Selitsky
Hi, Alvaro.
Unfortunately, I have never done reverse transformations (gamma-omega).
Your error may be caused by the use of the left coordinate system in Smath- graphs.
I selected the angles for the axial matrices empirically in order to get a good perspective ,using the gamma matrix.perspective.
Alvaro Diaz Falconi 10/9/2018 9:14:00 PM
#39 Posted: 10/10/2018 12:40:38 AM
Mathcad solves the Euler angles from a given γ [gamma matrix].
Smath does not immediately, it complains: Try to use a more specific algorithm.
There are 24 [4!] possible ways to define a 3D system [Mathematica].
The most common is Euler though Mathcad Mathcad ≠ Mathematica.
For common use to define some pleasant views, especially in Smath:
1. Euler [ 3 trig angles]
2. Parametric [X,Y,Z,t] very easy to manage.
3. Quaternion only two coefficients that Quaternion solves for the 3D γ matrix
Rotate Horn.sm (15 KiB) downloaded 111 time(s).
Solve Euler Fails.sm (22 KiB) downloaded 103 time(s).
Rotate Breather [Euler].sm (37 KiB) downloaded 108 time(s).
Rotate_0 Euler, xyz(t), Quaternion.sm (275 KiB) downloaded 106 time(s).
#40 Posted: 12/12/2018 12:57:19 PM
Updated.
Changes for al_rkckadapt():
- zero point issue fixed;
- added support for the simple D(t,x) definition.
[albumimg]1531[/albumimg]
frapuano 12/12/2018 2:31:00 PM, sergio 12/12/2018 1:54:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
