1 Pages (3 items)
RC 0.99.6648 (15 March 2018) - Messages
#1 Posted: 3/15/2018 2:06:33 PM
List of changes(between 0.99.6646 and 0.99.6648 versions)
Improvements
- Support for Shift+Enter keystroke (in addition to Ctrl+Enter) added for equations breaking;
- F11 keystroke handles Step In functionality now;
- Close button added to Debugging/Output panels;
- SS-2322: Ctl+A keystroke enabled into Output window;
- The following internal setting support implemented: NumbersOutputFormatDisambiguation=CurrentPreset (can be added into settings.inf content as a separate line) - it allows to open legacy files using new numbers format set into program options.
Corrections
- Displayed error occurred on incorrect break/continue usage fixed;
- Rendering of range(..) functions corrected;
- Slow performance of el(..) function in some cases when working with complex numeric expressions fixed;
- Inserting 'i' char after apostrophe symbol or as a first function's name letter fixed;
- SS-3511: Rendering of boolean equal operator improved;
- Result matrix resize symbols made agnostic to fonts available on the machine;
- Symbolic engine error causes evaluation abort fixed;
- Refactoring of the Calculation logic in a separate system thread performed (errors related to manual termination of the evaluation fixed);
- Mouse wheel handling by regions in Pages View mode fixed (it was impossible to use mouse wheel over some parts of the focused region);
- Replacing of function existing on the worksheet with another one using Dynamic Assistance list fixed;
- Select All (or Ctrl+A) inside a Worksheet allowed now when Calculation is in progress;
- Loading of the program became faster on some environment configurations;
- Vectorization operator improved to support more different cases.
Miscellaneous
- Errors handling logic reworked;
- Interface translations updated;
- Refactoring.
Download
SMathStudioDesktop.0_99_6648.Mono.tar.gz (1 MiB) downloaded 721 time(s).
SMathStudioDesktop.0_99_6648.Setup.msi (2 MiB) downloaded 2238 time(s).
5 users liked this post
Вячеслав Мезенцев 3/15/2018 2:21:00 PM, sergio 3/15/2018 3:09:00 PM, Alexander O. Melnik 3/15/2018 5:05:00 PM, frapuano 3/15/2018 6:35:00 PM, IVR 3/16/2018 12:28:00 PM
#2 Posted: 3/15/2018 2:26:52 PM
This is release candidate. Known observations are fixed. Tests passed OK. No new functionality will be implemented before next Stable release.
Best regards!
Best regards!
6 users liked this post
Arie 3/15/2018 4:54:00 PM, frapuano 3/15/2018 6:34:00 PM, NDTM Amarasekera 3/15/2018 2:48:00 PM, Radovan Omorjan 3/15/2018 2:58:00 PM, sergio 3/15/2018 3:08:00 PM, Jaan Praks 3/15/2018 5:47:00 PM
#3 Posted: 3/15/2018 7:33:54 PM
WroteNo new functionality will be implemented before next Stable release.
The word is stable release, I will borrow a Win7/10
Will be a big job to test all !
Cheers Andrey ... Jean
1 Pages (3 items)
New Posts
No New Posts
