Histogram Program
Histogram Program - Messages
#1 Posted: 1/11/2019 5:41:50 PM
Norm Schutzkus
Norm Schutzkus
9 likes in 90 posts.
I've come across a mathcad2000i worksheet that I converted to prime4, the attached pdf shows the results. I've attempted to reproduce the Histogram(X) routine in SMath but can't seem to get past the "Argument must be a vector..." error. I welcome the collabs review and recommendations if this routine will work.
Thank you,
#2 Posted: 1/12/2019 3:12:54 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Hi. Do you have the original Mathcad2000 worksheet?
Instead of parse a variable parameter number f(x,p1,p2,p3,...) you can use just f(x,p) but with p as a vector columns. With that you don't need replicate, Vec2Vec&Size and the other similar utilities.
#3 Posted: 1/12/2019 7:47:15 AM
1417 likes in 2873 posts.
routine for X-Y plot
hist.sm (14 KiB) downloaded 106 time(s).
frapuano 1/12/2019 8:33:00 AM
#4 Posted: 1/12/2019 11:30:09 AM
983 likes in 6866 posts.
I think, don't understand what you are trying to do ... few points:
1. NaN what introduce by Mathsoft during design of DAEP [2003]
2. NaN is not ∞ ... rather it is based on floating point error,
a pure decoration in Smath except if related to Maple.
3. Tom G. didn't have DAEP [300 $ in 2003]. Tom did lot of work based on NaN.
From recollection, he used ^307. I tried simulate NaN in Smath not to avail.4
4. In Mathcad, there are 17 styles random, all built-in from the universal
random uniform found in most systems.
5. 'rlogis' is useful in Monte-Carlo stuff, included in the attached.
6. Also attached: how to simulate normal random from the CLT
Central Limit Theorem.
7. If you are given a data set that looks bell shape, trying to fit that is
like lottery ... Why ?
8. Data are just data, they don't collect bell shape by themselves.
Some smart have binned them. Depending upon the binning you will get
all sorts of misleading PDF.
9. Added the PW weighted histogram c/w the original application that lasted
weeks that the originator had none of "thanks or equivalent" in his vocabulary.
Stat Monte Carlo [rlogis].sm (74 KiB) downloaded 67 time(s).
Stat Random normal USER.sm (123 KiB) downloaded 69 time(s).
Stat Histogram PW.sm (110 KiB) downloaded 63 time(s).
#5 Posted: 1/12/2019 11:45:31 AM
... Oh ! forgot to return your original
Probability Fitting[1].sm (90 KiB) downloaded 65 time(s).
#6 Posted: 1/12/2019 2:20:25 PM
Norm Schutzkus
Norm Schutzkus
Prob Fitting.xmcd (182 KiB) downloaded 55 time(s).
Thank you, David & Jean for your help and direction.
Alvaro, for your reference, attached is the worksheet, I believe by Tom Gutman.
Again, many thanks!
#7 Posted: 1/12/2019 2:30:37 PM
Yes, Tom Gutman
This demo to illustrate the CLT
Stat Histogram DEMO.sm (23 KiB) downloaded 62 time(s).
#8 Posted: 1/12/2019 9:33:48 PM
1222 likes in 2150 posts.
See Maxima docs for available functions and options
Streuung.sm (45 KiB) downloaded 64 time(s).
streug.rar (291 B) downloaded 57 time(s).
frapuano 1/13/2019 5:20:00 AM
#9 Posted: 1/13/2019 8:48:58 PM
From native Smath, you can have:
1. colors at will [rich from X_Y plot], even white to imitate no bar.
2. Slightly separated, joined, slightly overlapped.
3. solid or hatched at will.
Stat Histogram BarColor.sm (26 KiB) downloaded 72 time(s).
#10 Posted: 1/14/2019 12:48:22 AM
... or like this.
  • New Posts New Posts
  • No New Posts No New Posts
