1 Pages (3 items)
Table Problems, Possible bug? - Messages
#1 Posted: 7/28/2022 6:59:37 AM
I am trying to setup a table from extracted data from a matrix, but when I create the table I cant add the left stub, the image below shows 4 tables:
table 1 uses ls as the main body and I can add ζ.in as the right stub
table 2 use CSA.in as the main body and allows ls to be added as the left stub
table 3 the same as table 2 but using ζ.in as the main body
table 4 is the issue, here I can add the main body/header, but will not allow the addition of the left stub.
All 3 data sets appear to be the same, where have I gone wrong, or is there a bug?
sheet attached:Table errors.sm (32 KiB) downloaded 59 time(s).
#2 Posted: 7/28/2022 7:18:12 AM
I don't think it's a bug.
It happens for how you built the TB matrix. If you use "Augment" it works well.
Table_errors_s.sm (34 KiB) downloaded 80 time(s).
1 Pages (3 items)
New Posts
No New Posts
