f(x, y) - 3D plot and optimal point
f(x, y) - 3D plot and optimal point - Steam Turbine - Messages
#1 Posted: 11/6/2023 12:13:14 AM
Valery Ochkov
Valery Ochkov
55 likes in 633 posts.
I have f(x, y) - thermal efficiency of a steam turbine with two steam extractions for heating feed water depending on the extraction pressures.
Question.
1. How to find the optimal pressure values at which the efficiency will be maximum?
2. Is it possible to build a surface? For now I have two separate 2D graphics.
More https://link.springer.com/book/10.1007/978-3-319-26674-9
2RegP-Ideal-new.sm (94 KiB) downloaded 64 time(s).
#2 Posted: 11/6/2023 12:43:57 AM
Valery Ochkov
Valery Ochkov
No, you cannot replace WaterSteamPro with Cool Prop for water/steam.
WaterSteamPro is a certified program!
Compare please two plots
#3 Posted: 11/7/2023 3:44:54 AM
1222 likes in 2150 posts.
I am not familiar with CoolProps but I think I could make a nice 3D plot with Maxima if you provide the smath file
Valery Ochkov 11/7/2023 1:09:00 PM
#4 Posted: 11/7/2023 1:10:43 PM
Valery Ochkov
Valery Ochkov
Thanks, Martin!
Must be someone so
#5 Posted: 11/7/2023 2:53:03 PM
OK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
#6 Posted: 11/8/2023 1:05:10 PM
Valery Ochkov
Valery Ochkov
See please attach
2RegP-Ideal-Cool_Prop-95.sm (73 KiB) downloaded 66 time(s).
2RegP-Ideal-Cool_Prop-95.pdf (361 KiB) downloaded 65 time(s).
Martin (and all), I am waiting for the solution - 3D-plot and optimal values of p1 and p2.
#7 Posted: 11/8/2023 9:11:41 PM
Just the plot, no optimization yet.
2RegP-Ideal-Cool_Prop-95_Kr.sm (300 KiB) downloaded 63 time(s).
Oscar Campo 11/8/2023 9:22:00 PM, Valery Ochkov 11/8/2023 10:27:00 PM
#8 Posted: 11/9/2023 1:16:22 AM
Valery Ochkov
Valery Ochkov
No optimization yet.
For checking
#9 Posted: 11/9/2023 6:31:08 PM
983 likes in 6866 posts.
Agreed: CoolProp is CoolProp.
For quick visit, I use freeware Katmar IAPWS=97 in all sorts of units.
By same token, in Smath, we have lot of water/steam formulas.
What about you tabulate matrix style, then spline/interpolate.
I will be back on your document ... Jean
Valery Ochkov 11/9/2023 6:37:00 PM
#10 Posted: 11/10/2023 1:49:18 PM
Valery Ochkov
Valery Ochkov
#11 Posted: 11/11/2023 1:40:46 AM
... confirmed vs my formula IAPWS-97
#12 Posted: 11/12/2023 2:37:31 AM
For checking
I get slightly different values. Still no automatic optimization because the objective function doesn't translate to Maxima. As a first step I made the function more robust by solving the two equations sequentially instead of simultaneously. In the original version sampling for the plot occasionally failed.
Plot MPa.pdf (219 KiB) downloaded 56 time(s).
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (157 KiB) downloaded 55 time(s).
2023-11-11 19_21_55-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png
2RegP-Ideal-Cool_Prop-95_Kr_detail.pdf (520 KiB) downloaded 59 time(s).
Valery Ochkov 11/12/2023 2:41:00 AM, Alvaro Diaz Falconi 11/12/2023 9:04:00 AM
#13 Posted: 11/12/2023 2:51:46 AM
Valery Ochkov
Valery Ochkov
Wonderful!
But I dare to note that a real steam turbine unit has up to eight steam extractions from the turbine to regenerative heaters. And not only mixing, but also surface type.
#14 Posted: 11/12/2023 9:07:21 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
I get slightly different values. ...
Hi. Using the definition for partial derivatives and a pure numerical solver.
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (162 KiB) downloaded 58 time(s).
Martin Kraska 11/12/2023 9:10:00 AM, Valery Ochkov 11/12/2023 2:12:00 PM, Oscar Campo 11/12/2023 6:29:00 PM
#15 Posted: 11/14/2023 2:13:59 AM
Valery Ochkov
Valery Ochkov
  • New Posts New Posts
  • No New Posts No New Posts
