1 Pages (15 items)
plotG(data,char,size,clr) - plotG(data,char,size,clr) - Messages
#1 Posted: 2/17/2018 11:19:44 PM
This refactored style is ~ 25 times faster than the very original.
The nested style does not ring a bell about specific use ?
Random_8 Fill Critical Region.sm (17 KiB) downloaded 152 time(s).
#2 Posted: 2/18/2018 3:53:06 PM
Jean,
It does not work in 6622.
In Graph: (does not display any graph)
Error: Random()= Function is not defined.
Thanks,
Basile
Thanks,
Basile
#3 Posted: 2/18/2018 4:32:39 PM
#4 Posted: 2/18/2018 4:49:32 PM
#5 Posted: 2/18/2018 4:50:32 PM
WroteRandom(..) function is from Statistical Tools plug-in. Please check if this plug-in available on your PC.
#7 Posted: 2/18/2018 5:21:15 PM
#8 Posted: 2/18/2018 6:45:09 PM
#9 Posted: 2/18/2018 10:10:38 PM
WroteAm I doing something wrong?
Maybe YES, maybe NO ... maybe an undetected bug wrt your version,
though Andrey said/proved it works. If you visit "Samples", you
will find a huge "Random Utilities" [not more than a month old].
Cheers Basile, Jean
Basile Random.sm (8 KiB) downloaded 88 time(s).
#10 Posted: 2/19/2018 9:52:38 AM
#11 Posted: 2/19/2018 11:54:45 AM
WroteJean,
I run your and I get:
Basile
Sorry mon ami, the "Grand Doctors" is the next step.
"Random(,) not defined" does not mean error from the plugin,
rather it means the program does not recognize from incompatible code.
#12 Posted: 2/19/2018 2:46:31 PM
Not sure, but may be this is because of sort order of plug-ins or some additional plug-in which breaks the logic...
Please could you execute the following in command line? (path to SMathStudio_Desktop.exe may differ on your PC)
I would like to see the output of this command in order to try to reproduce this on my environment.
"C:\Program Files (x86)\SMath Studio\SMathStudio_Desktop.exe" -silent -info
Davide Carpi 2/19/2018 8:37:00 PM
#15 Posted: 2/21/2018 3:59:05 AM
Thank you very much! Now I have everything to try reproducing this issue.
1 Pages (15 items)
New Posts
No New Posts
