EXCEL (2003+) I/O with recalculation and export to PNG
EXCEL (2003+) I/O with recalculation and export to PNG - Uses EXCEL PIA (2003+) to import/export data to and from XLS/XLSX files - Messages
#101 Posted: 9/20/2021 2:18:08 PM
Ricardo_Herrera
Ricardo_Herrera
1 likes in 8 posts.
Quote
XLSXupdate.txt (1 KiB) downloaded 40 time(s).
first it is a great surprise is to be able to greet his person.
Thank you very much for your time. and by Smath Studio. Thank you very much for what you teach and what you do.
#102 Posted: 9/20/2021 4:14:43 PM
1402 likes in 1708 posts.
Please try to update the plugin. Your version is from last year and is out of date.
#103 Posted: 9/20/2021 4:48:37 PM
Ricardo_Herrera
Ricardo_Herrera
1 likes in 8 posts.
XLSXupdate.txt (1 KiB) downloaded 58 time(s).
Update plugin, but error persists.
Keep holding
#104 Posted: 9/20/2021 7:19:45 PM
This problem appears due to the presence of old keys in the registry, which will contain the wrong path to Excel. Try to search in Google for a solution to your problem using the error text from the log file:
Excel HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED)
#105 Posted: 9/21/2021 11:29:09 AM
João Felipe Seráfico Melo
7 likes in 62 posts.
Ricardo, I updated the plugin and made a Quick Repair in my Office 365, restarted the pc and now it works perfectly.
The issue is some bug in Office register.
Thank you for your compliments, Ricardo! Glad to see my videos are helping!
#106 Posted: 9/21/2021 12:37:50 PM
Ricardo_Herrera
Ricardo_Herrera
1 likes in 8 posts.
Thank you very much I have reinstalled office and now it works.
thanks for everyone's help.
A hug from a distance.
to all.
João Felipe Seráfico Melo 9/21/2021 2:48:00 PM
#107 Posted: 11/1/2021 8:46:47 AM
Hi! I'm having trouble sending String variables to Excel.
For instance, ". - / ! ? ;" turns into \002E\\0020\\002D\\0020\\002F\\0020\\0021\\0020\\003F\\0020\\003B\ in Excel.
I'm using most recent SMath and Excel I/O versions.
#108 Posted: 11/1/2021 10:05:32 AM
Ricardo_Herrera
Ricardo_Herrera
1 likes in 8 posts.
Hello, good morning, could I send a screenshot to see the error that generates a hug from a distance
#109 Posted: 11/10/2021 12:26:03 PM
oscar mauricio
oscar mauricio
1 likes in 10 posts.
Hi, I have the same problem as Ricardo, any recommendations to solve it?
Show Spoiler
#110 Posted: 11/11/2021 5:35:29 AM
SMath Studio compatibility
Plugin updated.
Changes:
- excel_in(): text encode issue fixed.
João Felipe Seráfico Melo 11/11/2021 8:48:00 AM, oscar mauricio 11/11/2021 8:49:00 AM
#111 Posted: 11/11/2021 8:57:18 AM
oscar mauricio
oscar mauricio
Thank you very much, fixed with update
#112 Posted: 7/3/2022 4:18:14 AM
Plugin updated.
Changes:
- added support for environment variables;
- refactored.
Alvaro Diaz Falconi 7/3/2022 5:03:00 AM
#113 Posted: 7/3/2022 5:04:57 AM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
Plugin updated. ...
Hi Viacheslav. An example about what does that mean? Thanks.
#114 Posted: 7/3/2022 6:10:06 AM
You can use operating system environment variables in the file path.
4 users liked this post
NDTM Amarasekera 7/3/2022 8:00:00 AM, churichuro 7/3/2022 12:59:00 PM, Alvaro Diaz Falconi 7/3/2022 3:51:00 PM, oscar mauricio 7/7/2022 11:37:00 AM
#115 Posted: 7/7/2022 11:54:58 AM
oscar mauricio
oscar mauricio
Hello thanks for the plugin, I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions.
#116 Posted: 7/8/2022 4:45:19 AM
Plugin updated. Please try.
Changes:
- ToCell(): Globals.Excel.DecimalSeparator replaced by the CultureInfo.GetCultureInfo( "en-EN" ).NumberFormat.NumberDecimalSeparator;
- ToCell(): Double.Parse() fixed;
- part of the book "Excel 2002 VBA Programmer's Reference" added (Chapter 22. International Issues).
Click to enlarge
oscar mauricio 7/8/2022 4:00:00 PM
#117 Posted: 7/8/2022 7:01:35 AM
It is possible to simplify the interface. I can add a new feature. You can suggest your own version for a new feature.
#118 Posted: 7/9/2022 6:43:56 AM
In a future release I will remove functions from ExcelIOCom to XLSXupdate. One function and one operand will be added.
churichuro 7/9/2022 11:09:00 AM, sergio 7/9/2022 11:20:00 AM
#119 Posted: 7/9/2022 12:41:31 PM
SMath Studio compatibility Examples
Changes:
- excel operand and excel() function added;
- readCell() and writeCell() moved from the ExcelIOCom plugin;
- examples added;
- refactored.
sergio 7/11/2022 5:47:00 AM
#120 Posted: 7/12/2022 3:40:45 AM
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable:
excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML"
Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as:
- create books, add and delete sheets;
- accessing named ranges;
I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable.
oscar mauricio 7/15/2022 9:52:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
