iterator argument of sum/product
iterator argument of sum/product - Messages
#1 Posted: 12/17/2016 3:36:38 PM
983 likes in 6866 posts.
... can' t understand what Smath does not like.
Worked so nice 5346 !
Fourier Budapest39 Spectrum.sm (36 KiB) downloaded 66 time(s).
MOD: reduced test file http://en.smath.info/forum/yaf_postsm35790_Stable--SMath-Studio-0-98-6128--11-October-2016.aspx#post35790
#2 Posted: 12/17/2016 4:27:39 PM
325 likes in 2052 posts.
If you mean on the errors regarding "B92(u)" function and "fit" matrix with the error: "Variable and function names can't start with a number", this is due to the unsolved problem of summation in the B2(u) function. We have to define this function with the line environment, although it is a single line function (summation causes the problem). I really do not know why this problem appeared in the recent versions and when/if is going to be solved.
#3 Posted: 12/18/2016 4:23:38 PM
If you mean on the errors regarding "B39(u)" function and "fit" matrix with the error: "Variable and function names can't start with a number", this is due to the unsolved problem of summation in the B39(u) function. We have to define this function with the line environment, although it is a single line function (summation causes the problem). I really do not know why this problem appeared in the recent versions and when/if is going to be solved.
Thanks Radovan,
You have doctored/rescued the 3 work sheets.
Only B39(u) needs the local line definition.
The A's B's coefficients MUST NOT have local line definitions.
  • New Posts New Posts
  • No New Posts No New Posts
