3D Rotation Matrix
3D Rotation Matrix - Messages
#1 Posted: 10/9/2018 9:29:00 PM
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 likes in 1675 posts.
From: https://en.smath.info/forum/yaf_postsm54527_AlgLib-3-1x.aspx#post54527
Hi Ber7. Thanks for the angles, which gives this beatifull view point!
Your error may be caused by the use of the left coordinate system in Smath- graphs.
Using SMath convention for axis it's very difficult to me, and also add the fact that in Latin America we use this as Euler angles:
https://es.wikipedia.org/wiki/%C3%81ngulos_de_Euler
In the attached, I can invert emulating the matlab robots toolbox's rotm2eul.m function, but notice that I need to swap the product order to get the same matrix with those angles that I obtain first.
So, I don't sure now if we are doing the rotations ok taking Ω1*Ω2*Ω3 or, for SMath, the correct order is Ω3*Ω2*Ω1, and this swap is the math meaning for "left coordinate system".
rotm2eul.sm (83 KiB) downloaded 78 time(s).
Fridel Selitsky 10/9/2018 10:51:00 PM, sergio 10/10/2018 4:33:00 AM, frapuano 10/10/2018 5:31:00 AM
#2 Posted: 10/10/2018 2:53:22 PM
983 likes in 6866 posts.
So, I'm not sure now if we are doing the rotations ok taking Ω1*Ω2*Ω3 or, for SMath, the correct order is Ω3*Ω2*Ω1, and this swap is the math meaning for "left coordinate system".
Euler traditional [Roll, Pitch, Yaw] is not commutative once angles are defined.
Some 3D solids will show convenient in any of the possible 3! = 6 commutative.
Rotate Euler NOT Commutative.sm (16 KiB) downloaded 87 time(s).
NDTM Amarasekera 10/10/2018 3:03:00 PM, sergio 10/10/2018 5:32:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
