1 Pages (15 items)
corrupted file - Ioan - Messages
#1 Posted: 7/3/2012 1:00:15 AM
Hi all,
Trying to reopen a file that I wrote and that refused to be closed normaly, I receive this message:
I posted the file here:
file
Is it possible to recover the file ? If yes, how ?
Thanks a lot for any help,
Ioan
NMyMz.zip (454 KiB) downloaded 55 time(s).
"Unexpected end of file occured.
The following elements are not closed:
result, math, region, regions. Line 82490, position 12."
file
Ioan
#2 Posted: 7/3/2012 2:53:34 AM
Please attach your file to the forum: http://en.smath.info/forum/yaf_help_index.aspx?faq=attachments
#3 Posted: 7/3/2012 2:56:52 AM
the link to the file points to a hoster which requires login/registration. I won't create a login at a filehoster just to download a single file. You might use dropbox or the smath wiki file management.
The problem might be solved by just closing the xml tags in the file, but I can't try...
If that is the solution than I guess that SMath should be able to propose this approach and apply the fix.
Best regards, Martin
#4 Posted: 7/3/2012 3:14:56 AM
I agree, Ioan please attach the file directly to the forum or use a registration-free hosting service...
The solution is indicated by mkraska and the result is in the attached file
regards,
w3b5urf3r
WrotePlease attach your file to the forum: http://en.smath.info/for...dex.aspx?faq=attachments
WroteThe problem might be solved by just closing the xml tags in the file
regards,
w3b5urf3r
#5 Posted: 7/3/2012 3:27:58 AM
Thanks for your answers,
Many thanks to w3b5urf3r for the recovered file.
Now the original file is attached to my first post.
I still have a problem with this file:
all results are in fractional mode, against my temptatives of changing.
#6 Posted: 7/3/2012 7:18:06 AM
You are welcome
simply change the result optimization from "none" to "numeric"
regards,
w3b5urf3r
Wroteall results are in fractional mode, against my temptatives of changing.
regards,
w3b5urf3r
#7 Posted: 7/3/2012 7:28:43 AM
Thanks again w3b5urf3r.
Best regards to all,
Ioan
Ioan
#8 Posted: 9/7/2012 9:13:34 AM
Hello there,
I have similar problem with my document. I saved file on hard disk but when i reopened it all text below pagebreak stamp disappeared.
Please look at it, help if possible it is important for me.
File with lost data.sm (483 KiB) downloaded 64 time(s).
#9 Posted: 9/9/2012 12:09:04 PM
I don't find anything wrong with your file. It opens fine on my computer with Win 7 and SMath 0.95. You have collapable areas within a collapsable area.
Ed
#10 Posted: 9/18/2012 3:40:08 AM
Hi there,
I have one more corrupt file. This time I can not even open it.
Thanks for every help.
ZELBET_Przebicie_PNB_03264_2002_v1.sm (497 KiB) downloaded 72 time(s).
#11 Posted: 9/18/2012 4:19:53 AM
WroteHi there,
Hi Anonymous,
The recovered file is in the attachments.
@Andrey The issue is in these lines, at the end of the Anonymous original file...
<region id="163" left="0" top="7227" width="326" height="334" color="#000000" bgColor="#ffffff" fontSize="10">
<math error="9">
<input>
<e type="operand">Typ</e>
<e type="operand" style="string">1</e>
<e type="operator" args="2">≡</e>
<e type="operand">A</e>
<e type="operand">b</e>
<e type="operand">2</e>
<e type="operand">d</e>
<e type="operator" args="2">*</e>
<e type="operator" args="2">+</e>
<e type="bracket">(</e>
<e type="operand">1</e>
<e type="operator" args="2">:</e>
<e type="operand">A.2</e>
<e type="operand" style="string">Nie dotyczy</e>
<e type="function" preserve="true" args="4">line</e>
<e type="operand" style="string">2</e>
<e type="operand" style="string">3</e>
<e type="operator" args="2">|</e>
<e type="operand">B</e>
<e type="operator" args="2">-</e>
<e type="operand">H</e>
<e type="operand">h</e>
<e type="operator" args="2"><</e>
<e type="operand">L</e>
<e type="operand">l</e>
<e type="operator" args="2">&</e>
<e type="operand">d.1</e>
<e type="operator" args="2">≥</e>
<e type="operand">d.2</e>
<e type="operand">#</e>
<e type="function" preserve="true" args="5">line</e>
<e type="function" preserve="true" args="2">if</e>
<e type="function" preserve="true" args="4">if</e>
<e type="function" preserve="true" args="3">if</e>
</input>
</math>
</region>
regards,
w3b5urf3r
ZELBET_Przebicie_PNB_03264_2002_v1.sm (492 KiB) downloaded 59 time(s).
#12 Posted: 9/21/2012 7:45:29 AM
Thanks for help w3b5urf3r. It is working now.
#13 Posted: 12/27/2013 8:02:04 PM
Unfortunately I have a similar problem with my file.
After I finished my document it didn't saved somehow and now when I'm trying to open it I just see a grey background
I would be really grateful if someone could help me with it, because it's very important for me.
Best regards,
Ann
Słupy.sm (2 MiB) downloaded 16 time(s).
Best regards,
Ann
1 Pages (15 items)
New Posts
No New Posts
