1 Pages (8 items)
Ellipse and... go to bugs - Is it one SMath bug? - Messages
#1 Posted: 9/7/2023 11:05:14 AM
My students were building a multifocal ellipse and... almost went crazy. My ellipse is correct, but the student's is incorrect. Although the formulas are the same.
Can you guess where the error is and whether it is necessary to modify SMath so that such an error is visible?
Do you know more some examples?
Ellipse4.sm (11 KiB) downloaded 66 time(s).
#2 Posted: 9/7/2023 11:47:49 AM
In fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
Valery Ochkov 9/7/2023 1:42:00 PM
#3 Posted: 9/7/2023 11:58:54 AM
#4 Posted: 9/7/2023 12:00:34 PM
WroteIn fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
You can also select/double-click the sum symbol to check what belongs to it.
#5 Posted: 9/7/2023 12:01:59 PM
The problem is that in the first Ellipse(x,y) definition, variable S is outside Sum function, but in the definition of your students is inside:
Your definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2),i,1,N)-S
Student´s definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2)-S,i,1,N)
Maybe, this explicit form is most clear for students:
Your definition:
#7 Posted: 9/7/2023 2:24:15 PM
WroteBetter so ...
You can tell your students that you are using the Note under Example 3 of point 7.1.3 of ISO 80000-1:2009(E) Quantities and units, Part 1: General.
#8 Posted: 9/7/2023 3:28:30 PM
1 Pages (8 items)
New Posts
No New Posts
