How to write a over dot & double subscript levels?
How to write a over dot & double subscript levels? - Messages
#1 Posted: 7/19/2016 6:11:30 AM
Topaz
Topaz
0 likes in 6 posts.
i have to questions at the moment:
-is it possible to write a overdot like for the volumetric flow rate?
-how could i write double subscripts?
e.g.:
Many thanks in advance!
#2 Posted: 7/19/2016 6:54:08 AM
csb531
csb531
0 likes in 24 posts.
Hello Topaz,
I have no answer to your first question - I don't know.
Maybe another user has a solution for that.
To your second question:
as far as I know (and use), you can only write one (1) subscript, but you can than add an index number with the "[" key.
in fact you define a vector.
see the attached fileFile not found.File not found.
kind regards,
csb
#3 Posted: 7/19/2016 9:43:58 AM
983 likes in 6866 posts.
In maths works ang Engineering works, subscripts are confusing.
To me: completely useless, never use. Occasionaly, as short
description is usefull to evidence the RHS construction.
Further, Smath is very limited in the ASCII 'Alt+0key'. Probably
because of the so many languages it was designed to accomodate.
NONE of my Smath Engineering work sheet contains subscript.
Inst_Colebrook Pipe Data.sm (60 KiB) downloaded 55 time(s).
Inst_Orifice Plate.sm (430 KiB) downloaded 47 time(s).
#4 Posted: 7/19/2016 9:55:34 AM
csb531
csb531
@ Topaz
As you can see in the reply from Jean, you can use - as a workaround - the underscore in the subscript:
Hope this works for you.
Regards, csb
#5 Posted: 7/19/2016 3:52:35 PM
Yes, csb531: underscore is a variable name by itself,
like this ... _(x):=sin(x)
or as a "union/separator" in variable name definition
as well as "union/separator" in subscripted text.
  • New Posts New Posts
  • No New Posts No New Posts
