Language-Integrated Query (Linq)
Language-Integrated Query (Linq) - Useful functions for working with sets. - Messages
#1 Posted: 4/24/2014 11:03:35 PM
1402 likes in 1708 posts.
Language-Integrated Query (Linq).
Functions list:
`if(2), `if(3), select(2), select2(2), selectmany(2), join(5), where(2), where2(2), aggregate(2), aggregate(3), take(2), takewhile(2), takewhile2(2), skip(2), first(2), repeat(2), any(2), all(2), contains(2), count(2), batch(2), batch(3), exclude(3), takeevery(2).
Links:
1. LINQ - Language-Integrated Query.
2. morelink - Extensions to LINQ to Objects (jonathan.skeet, ...).
Linq. Examples.sm (37 KiB) downloaded 143 time(s).
5 users liked this post
Serg 8/29/2016 10:47:00 AM, Martin Kraska 4/25/2014 2:52:00 AM, Davide Carpi 4/25/2014 4:47:00 AM, Mike Kaganski 4/25/2014 8:03:00 AM, Radovan Omorjan 4/25/2014 1:28:00 AM
#2 Posted: 4/25/2014 2:59:17 AM
1222 likes in 2150 posts.
Uni, the way you provide arguments to your functions looks interesting. How is it expected to work, does it really what it should? What are the formal restrictions? This is not even known for ordinary function arguments, thus I wonder how thin the ice is that you are on ;-)
#3 Posted: 4/25/2014 3:42:57 AM
325 likes in 2052 posts.
I totally forgot that this is possible in SMath
[MATH=eng]f(x,`):`(x)^2[/MATH]
[MATH=eng]f(x:6,`(x):x)=36[/MATH]
[MATH=eng]f(y:7,`(x):x+1)=64[/MATH]
Uni used quite unusual character for a function name (`).
I forgot this as well (making a function argument call by value)
[MATH=eng]f(x):line(x:9,x^2,2,1)[/MATH]
[MATH=eng]a:100[/MATH]
[MATH=eng]f(a)=81[/MATH]
[MATH=eng]a=9[/MATH]
Contrary to
[MATH=eng]b:100[/MATH]
[MATH=eng]f(b:b)=81[/MATH]
[MATH=eng]b=100[/MATH]
#4 Posted: 4/25/2014 4:59:06 AM
1417 likes in 2873 posts.
Very nice functions Viacheslav
I think that also contains() should contains a break to maximize the performances.
Sometimes happens :d
Вячеслав Мезенцев 4/25/2014 5:30:00 AM
#5 Posted: 4/25/2014 5:25:22 AM
`(...) := (...) - lambda expression. This is an imitation of an implicit function in SMath Studio.
I wrote it for fun. But in this way you can check out the features of the program. I think this will SMath Studio future.
You can add here your own versions of these functions.
The ice is very thin, but it works I used this technique when solving the ODEs (D(t,x):=...). With regard to the restrictions, I do not see them for now.
These functions should work as vector functions, hiding the use of cycles.
Davide Carpi 4/25/2014 9:42:00 AM
#6 Posted: 4/25/2014 6:30:30 AM
Updated. Small improvements.
P.S. Here, the aggregate function is implemented not correctly.
Mike Kaganski 4/25/2014 8:16:00 AM
#7 Posted: 4/25/2014 8:17:32 AM
Mike Kaganski
Mike Kaganski
184 likes in 434 posts.
I have a feature request: please allow MULTIPLE thanks to uni! (Well, on second thought, I'm afraid I could break my left muse button then...)
С уважением, Михаил Каганский
Davide Carpi 4/25/2014 1:00:00 PM, Вячеслав Мезенцев 4/25/2014 8:50:00 AM
#8 Posted: 4/25/2014 8:58:34 AM
Updated. aggregate() - fixed.
#9 Posted: 4/25/2014 11:34:29 AM
Ryan Freund
Ryan Freund
19 likes in 339 posts.
I'm not sure if it is worth your time to explain but what is this?
Why is it beneficial?
Sorry for my ignorance.
#10 Posted: 4/25/2014 12:27:11 PM
It's not so easy for me to explain what is it for. I must implement basic functions, then it will be possible to show by examples why it maybe useful.
Moreover, it is quite complicated examples. With their help, you can test the Smath Studio.
#11 Posted: 4/25/2014 12:52:33 PM
LINQ is for C# a write less/do more extension (like jQuery for javascript); in a short expression there are lot of basic instructions.
here you can found a good overview of LINQ; because was born to handle in a better way databases in C# (even if today is like a programming language itself), it's a good project also to use it with SMath's matrices (a database in the end is only a matrix with types fixed for each column)
#12 Posted: 4/25/2014 5:49:29 PM
Updated.
Unfortunatelly, nested queries not supported.
Davide Carpi 4/25/2014 6:24:00 PM, Radovan Omorjan 4/26/2014 2:42:00 AM
#13 Posted: 4/25/2014 6:57:58 PM
Plot example.
[albumimg]350[/albumimg]
Linq. Plot.sm (7 KiB) downloaded 81 time(s).
Radovan Omorjan 4/26/2014 2:42:00 AM, Davide Carpi 4/25/2014 9:10:00 PM
#14 Posted: 4/25/2014 7:22:45 PM
selectmany example.
[albumimg]351[/albumimg]
Linq. selectmany.sm (7 KiB) downloaded 78 time(s).
#15 Posted: 4/25/2014 8:43:19 PM
ODE plot.
[albumimg]352[/albumimg]
Linq. ODE plot.sm (10 KiB) downloaded 91 time(s).
Radovan Omorjan 4/26/2014 2:43:00 AM, Davide Carpi 4/25/2014 9:10:00 PM
#16 Posted: 4/26/2014 8:24:15 AM
Updated. join(5) added.
Linq. join.sm (8 KiB) downloaded 83 time(s).
#17 Posted: 4/26/2014 12:00:06 PM
Updated. batch(2), batch(3) added.
Linq. batch.sm (9 KiB) downloaded 85 time(s).
Davide Carpi 4/26/2014 12:29:00 PM
#18 Posted: 4/27/2014 12:47:38 PM
An high-productively hint to anyone that want to use this useful extension but (like me) does not have a keyboard with the backtick/backquote (grave accent) symbol:
1. Download the AutoHotKey free tool (full-installation or portable, both for 32 and 64 bit machines) (link)
2. Unzip and launch the script attached here (with the portable app you can drag the file over the executable)
This script enable the following shortcuts:
- hold down the Windows Key and press ' to produce the backtick `
- hold down the Windows Key and press numbers to produce numpad numbers (this is useful on notebook w/o numpad)
Best regards,
Davide
P.S. the script can be customized to change the keys combinations and can be launched automatically on windows startup.
edit: the 2nd attachment "shortcuts_exe.zip" is a portable executable compiled from the script that enable the features described above without downloading the tool and the script.
shortcuts_exe.zip (793 KiB) downloaded 80 time(s).
#19 Posted: 4/28/2014 5:16:52 AM
MC15 works much faster.
Mathcad - Linq.pdf (70 KiB) downloaded 126 time(s).
#20 Posted: 4/29/2014 9:59:54 AM
kilele
kilele
133 likes in 397 posts.
Hi, I've seen the autohotkey script shared by Davide in this thread and thought that this .ahk might be of interest for someone, place the mouse over the screen top to bring it up. You can add other symbols by editing the script.
charsbar.zip (1 KiB) downloaded 89 time(s).
  • New Posts New Posts
  • No New Posts No New Posts
