1 Pages (15 items)
Numerical parameterization implicit surfaces of the form f (x, y, z) = 0 - Messages
#1 Posted: 5/29/2015 8:25:23 PM
The grid lines are found by Draghilev Method
Method 1.
Building a line of intersection of the required surface
with the plane x = 0. This line is rotated in steps of 2 * Pi / s
about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines)
Method 1.
Davide Carpi 5/31/2015 7:19:00 AM
#3 Posted: 12/17/2016 6:17:47 PM
The graph an implicit surface depicted by lines
Examples of the idea of the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/questions/219995-Finding-A-Convinient-Parametrization-Of-Surfaces#answer233804
File not found.File not found.File not found.File not found.File not found.
Вячеслав Мезенцев 12/19/2016 1:43:00 AM, Davide Carpi 12/18/2016 7:04:00 PM, frapuano 12/18/2016 5:42:00 AM
#4 Posted: 1/29/2017 4:56:41 PM
Two surfaces are taken from the site
http://xrt.wikidot.com/gallery:implicit
The calculation algorithm:
1.Find the line of intersection of the given surface with the plane Z=0
2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface.
Davide Carpi 1/30/2017 9:18:00 AM
#5 Posted: 1/29/2017 11:28:16 PM
Thanks for these two animations. In each one, the last three plots
stay red, though the animated plot works fine. A small detail:
each work sheet has three definitions left over at page 17.
#6 Posted: 1/30/2017 3:51:39 AM
Thank you Jean,
Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C:
double torus x2.sm (73 KiB) downloaded 81 time(s).
#7 Posted: 1/31/2017 5:50:55 PM
The tube in the form of a line of intersection of the cylinder and the torus (See post 7)
http://en.smath.info/forum/yaf_postst2307_Method-A-B--Draghilev-and-animation-spatial-mechanisms.aspx
Time calculation, 9 min.
Villarceau 9.sm (39 KiB) downloaded 71 time(s).
Davide Carpi 2/1/2017 5:58:00 AM
#9 Posted: 3/1/2017 4:44:07 AM
The surface of the Wikipedia
https://en.wikipedia.org/wiki/File:Tri-brezel.svg
WiciSurf.sm (106 KiB) downloaded 78 time(s).
Davide Carpi 3/1/2017 6:42:00 AM
#10 Posted: 6/14/2017 1:27:49 PM
Non-circular cylindrical vessels with quasi-ellipsoidal ends
Krivoshapko S.N. Ivanov V.N,Encyclopedia of Analytical Surfaces ,Springer,2015
Non-circular cylindrical vessels.pdf (1 MiB) downloaded 88 time(s).
Non-circular cylindrical vessels.sm (209 KiB) downloaded 75 time(s).
Shell1.sm (255 KiB) downloaded 76 time(s).
Shell2.sm (33 KiB) downloaded 72 time(s).
Shell3.sm (34 KiB) downloaded 74 time(s).
#11 Posted: 6/15/2017 9:43:57 AM
Thanks Ber7 for the work sheets [Not finished downloading].
If you visit this document, I'm wondering:
"How to add red points in this plot".
Thanks in advance ... Jean
Maths sph2xyz.sm (13 KiB) downloaded 74 time(s).
#12 Posted: 6/15/2017 12:23:51 PM
Hello Jean,
Unfortunately, the 3d chart does not allow you to draw points.
Exit (hopefully temporary) -make a 3d chart on a 2d chart.
Maths sph2xyz2d.sm (21 KiB) downloaded 83 time(s).
#13 Posted: 2/6/2018 3:56:52 AM
frapuano 2/6/2018 4:34:00 AM, Martin Kraska 2/6/2018 4:59:00 AM, Radovan Omorjan 2/6/2018 6:22:00 AM
#14 Posted: 2/6/2018 5:06:49 AM
Nice examples!
Just some remarks for those who want to play around with Maxima Draw.
ImplicitMaxima_Kr.sm (492 KiB) downloaded 78 time(s).
![2018-02-06 08_55_49-SMath Studio - [ImplicitMaxima.sm_].png](/en-US/file/BoD4rH/2018-02-06-08_55_49-SMath-Studio---_ImplicitMaxima_sm___png)
- Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
Insert-> Maxima-> Draw3D - The performance isn't overwhelming, as the image is recalculated for each interaction.
- The snippet "draw" provides help texts for the available draw commands and options.
- Follow the link in my signature to see how to configure SMath with Maxima.
4 users liked this post
Вячеслав Мезенцев 2/6/2018 6:15:00 AM, Radovan Omorjan 2/6/2018 6:22:00 AM, frapuano 2/6/2018 10:28:00 AM, Fridel Selitsky 2/6/2018 5:08:00 AM
1 Pages (15 items)
New Posts
No New Posts
