Run exe file in DOS from Smath
Run exe file in DOS from Smath - Messages
#1 Posted: 7/9/2018 1:39:58 PM
Oscar Ugaz
Oscar Ugaz
3 likes in 2 posts.
Guys,
1) Is it possible to run an .exe file from a DOS shell within Smath, and how ?
2) Could it be done by writing a Visual Basic script in the script window inside Smath ?
If so, could someone provide a small example of this.
Thank you for your help.
Oscar
#2 Posted: 7/10/2018 7:59:25 AM
1230 likes in 2155 posts.
The image region plugin demonstrates that you can run windows programs from within SMath.
If you register a dos program as standard application for png images, then the image region should launch this program whenever you try to create/edit the image.
Note that this might be considered as a security issue.
#3 Posted: 7/18/2018 2:51:21 PM
1403 likes in 1708 posts.
Try this.
Arie 7/18/2018 4:50:00 PM, frapuano 7/18/2018 5:17:00 PM
#4 Posted: 7/19/2018 5:39:12 AM
1418 likes in 2874 posts.
You can even use an hperlink region.
Absolutely. Assuming you are able to identify the threats, hyperlink regions are filtered by the user action (click of the user on the link), script region can be filtered by disabling auto calculation (before opening the worksheets).
  • New Posts New Posts
  • No New Posts No New Posts
