Parallel Piping Hazen Williams
Parallel Piping Hazen Williams - mathcad to mathstudio - Messages
#1 Posted: 3/22/2022 9:10:34 AM
Erick Valentino
Erick Valentino
7 likes in 28 posts.
Hello! What's up
I would like to know how I can replace the "given" command from Mathcad to SmathStudio, I know that such a command does not exist in SMATH and for that there are other tools
I just need to find the flows Q1 Q2 and Q3 from a parallel pipe using the Hazen Williams equation, without having to do as many expressions
Thank you very much
Another question... I was thinking of making tutorial videos preferably using SMath Studio over any other software called Mathcad, MathCad Prime, Maple, Matlab, Matematica, etc.
Can the new paid version still use the plugins MAPLE, Cool Proops, Maxima, etc. for free? Or will they have to pay for it?
thank you very much, you are a very cool community
Tuberias en Paralelo Hazen Williams.sm (13 KiB) downloaded 74 time(s).
Tuberias en Paralelo Hazen Williams.xmcd (26 KiB) downloaded 50 time(s).
[albumimg]1662[/albumimg]
#2 Posted: 3/22/2022 10:20:17 AM
1402 likes in 1708 posts.
Quote
You can use Mathcad Block region for this.
Click to enlarge
All my plugins will remain free.
Erick Valentino 3/22/2022 7:55:00 PM, sergio 3/22/2022 5:33:00 PM
#3 Posted: 3/22/2022 3:26:58 PM
554 likes in 1333 posts.
AFAIK, roots() won't work with units.
You can use FindRoots() for that purpose.
Regards.
tuberias.sm (11 KiB) downloaded 55 time(s).
Erick Valentino 3/22/2022 7:55:00 PM, Вячеслав Мезенцев 3/22/2022 5:34:00 PM
#4 Posted: 3/22/2022 5:35:27 PM
Or like this.
tuberias_uni.sm (12 KiB) downloaded 68 time(s).
Erick Valentino 3/22/2022 7:55:00 PM, overlord 3/22/2022 8:56:00 PM
#5 Posted: 3/22/2022 8:59:10 PM
Or like this.
What the..? I didn't know you can use mathblock like this.
How FindRoot() can work under block with only one argument?
That is a very neat feature. Really appreciate you share this.
#6 Posted: 3/23/2022 12:32:03 AM
The first argument is implicitly substituted by the block itself. Then the function is called with two arguments.
Click to enlarge
#7 Posted: 3/24/2022 9:00:06 AM
983 likes in 6866 posts.
Given/Find/Maximize/Minimize/Minerr/ODEsolve
1. Given/Find ... inspect Butler attached
2. Given/Minerr ... from iterative Smath code
In many instances superior to Minerr.
Given/ODEsolve from very many Smath ODE solvers.
Visit the code from Viacheslav [Uni]
Solve Given_Find [CO2_6179 Butler] Copy.sm (165 KiB) downloaded 52 time(s).
#8 Posted: 3/24/2022 2:25:53 PM
Does mathcadblock could be used with al_nleqsolve() with this example?
And I think it would be nice if block can be inserted with command.
Not just from Insert menu, regards.
#9 Posted: 3/24/2022 3:29:50 PM
It can't be done directly. But in general it is possible. I can create generic functions Find and Minerr which can be customized to a specific function. Working with the Mathcad Block should be universal. The GNU Scientific Library has a number of functions for finding roots and minimizing. I want to first test the Mathcad Block on a set of different functions before offering a solution. Already existing solvers also need to be somehow connected in a universal way. Now I have not found a common approach to solve this problem as a whole.
1. One Dimensional Root-Finding
2. Multidimensional Root-Finding
3. One Dimensional Minimization
4. Multidimensional Minimization
sergio 3/25/2022 8:04:00 AM
#10 Posted: 3/24/2022 3:41:17 PM
I can add a keyboard shortcut. What about [Ctrl]+[Shift]+[B] ?
#11 Posted: 3/24/2022 3:57:55 PM
Unfortunately GNU Scientific Library doesn't work with mono, so it is not usable under Linux.
I don't want to be rude but why it is called Mathcad Block?
MathBlock would suits it more, just a suggestion.
#12 Posted: 3/24/2022 4:09:40 PM
It is located in the Mathcad Toolbox plugin and was created to repeat the generalized ODE solver from Mathcad. This is made for the future for the converter. I hope that someday the converter from Mathcad will be finalized and there should be unambiguous equivalents for it. Therefore, I try to fill the Mathcad Toolbox plugin with similar functions. There are many interesting documents and it would be great if they were completely converted. It would also make it easier to transfer documents and users
I specifically set this name so that it does not interfere with the appearance of another similar block. Perhaps, after using the block, an understanding will come of how to make it a more convenient. For this case we will reserve this name (MathBlock).
  • New Posts New Posts
  • No New Posts No New Posts
