Signals and Systems
Signals and Systems - Example of use of SMath for signals and systems analysis - Messages
#1 Posted: 5/29/2012 4:14:49 PM
Oscar Campo
Oscar Campo
124 likes in 298 posts.
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Inverse numerical Laplace
Download it here
Oscar Campo
kmihaylovich 5/30/2012 2:28:00 AM, Davide Carpi 5/29/2012 6:13:00 PM, Radovan Omorjan 5/30/2012 3:00:00 AM
#2 Posted: 5/30/2012 3:09:26 AM
325 likes in 2052 posts.
Hello Oscar,
Thank you for this example
By the way, I find very interesting that you defined an expression in this way an then plot it:
Function<->variable
ft() looks like a function, but it is not.
Davide Carpi 5/30/2012 7:29:00 AM
#3 Posted: 5/30/2012 7:10:43 AM
Oscar Campo
Oscar Campo
Yes, it's something that I found accidentally. The statement ft(F(s)) appear as a function, but it's a matrix!
Oscar
#4 Posted: 5/30/2012 3:18:43 PM
Basile
Basile
8 likes in 172 posts.
I tried to open it using the latest SMath.
I get an error message in the last FOR loop: "Function not defined"
Thanks,
Basile
#5 Posted: 5/30/2012 3:53:17 PM
2271 likes in 3736 posts.
[USERLINK]Basile[/USERLINK], you need to define a function to work with as shown in the first message.
numerical inverse Laplace Transform
Regards.
#6 Posted: 5/31/2012 9:25:59 PM
Basile
Basile
Thank you Andrey,
Basile
#7 Posted: 5/31/2012 9:28:48 PM
Basile
Basile
Oscar,
Which Numerical Inverse Laplace Transform do you use?
Any reference?
Thank you,
Basile
#8 Posted: 6/1/2012 9:24:33 AM
Oscar Campo
Oscar Campo
Hi Basile,
The method is based on work of J. Valsa and L. Brancik: Approximate Formulae for Numerical Inversion of Laplace Transforms, Int. Journal of Numerical Modelling: Electronic Networks, Devices and Fields, Vol. 11, (1998), pp. 153-166
Oscar
Davide Carpi 6/1/2012 9:32:00 AM
#9 Posted: 6/1/2012 5:29:58 PM
Basile
Basile
Oscar,
Thank you,
Basile
#10 Posted: 6/4/2012 7:47:33 PM
Oscar Campo
Oscar Campo
Bode Diagram Revisited.
This is a function for graphing the Bode plot of a system. Please plot the magnitude and phase on a diferent graph each one, deactivate "grid" and "axis" for a better visualization of logarithmic grid.
Bode Plot
Download it here: MyBode3.sm (30 KiB) downloaded 63 time(s).
#11 Posted: 6/5/2012 3:02:37 PM
Oscar Campo
Oscar Campo
Root Locus Snippet
This is a snippet for plotting Root Locus of a sistem. The input is the denominator of coefficients of transfer function:
rlocus
Download it here
Oscar
#12 Posted: 8/25/2017 1:22:41 PM
Leandro de Oliveira
Leandro de Oliveira
0 likes in 1 posts.
The file seems to be locked, I can't put a equation.
#13 Posted: 8/25/2017 5:02:19 PM
983 likes in 6866 posts.
.. here is the Bode Plot.
Bode plot.sm (27 KiB) downloaded 215 time(s).
Viktor 11/15/2017 7:30:00 PM, Oscar Campo 8/27/2017 3:21:00 AM
#14 Posted: 8/25/2017 6:44:35 PM
1417 likes in 2873 posts.
Open the file in SMath Studio and then go to File > Properties > File Attributes and uncheck Read-only. This attribute is required when the worksheet is designed to be a snippet.
#15 Posted: 8/26/2017 9:01:49 AM
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expressed in F(s) form. enjoy
This 5 years old document does not work 6179.
Here is the Maple companion.
#16 Posted: 8/27/2017 10:46:55 AM
Oscar Campo
Oscar Campo
Only a very little detail to fix this 5 years old document: declare F(s) and change the last line on snippet:
ft( "F(s" ) = augment(t,ft)
for
ft() = augment(t,ft)
You can download the updated version from here
Davide Carpi 8/28/2017 1:28:00 PM
#17 Posted: 8/28/2017 11:01:53 AM
... that's only several pages long of HTML code.
No work sheet. Best is to upload WS in the forum.
For "Laplace stuff", better use maple(,) as show above.
Cheers, Jean
#18 Posted: 8/28/2017 11:32:53 AM
Oscar Campo
Oscar Campo
Use "save as"
Quote
Yes, and also it’s possible use f(t)=Maxima(ilt(F(s),s,t)) but it’s interesting show how you can implement inverse Laplace of a function in SMath.
P.D. The symbolic form of f(t) obtained from ilt() it’s more “elegant” than maple version
#19 Posted: 8/28/2017 1:04:34 PM
Win 7 does not have the virtue to save HTML "save as" *.sm
OK: no work sheet => nothing to see. Tanks anyway.
Cheers, Jean
#20 Posted: 8/28/2017 1:24:42 PM
You can if you use firefox (with chrome you have to change the extension manually from .txt to .sm);
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Oscar Campo 8/28/2017 2:23:00 PM
  • New Posts New Posts
  • No New Posts No New Posts
